Question about Sunpentown Heating & Cooling
SPT Sunpentown WA-9000E portable air conditioner. The air is not coming out that cold anymore. Needs recharge, not sure what kind of recharge kit to get.
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Why is my sunpentown WA-1210H portable AC not
Might be a dirty filter, a burnt compressor wire or a bad capacitor. Or it could be a bad thermostat.
Posted on May 10, 2009
How much water do I need for the air conditioner
I've never seen an air condition device that needs to add water to work. Actually they RELEASE condensation water and you need to collect this water or drain it through a tube
Jul 20, 2015 | Sunpentown Spt Tn-12e Technitrend...
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
Hi my wa-121oe is not blowing cold anymore
hi.maybe your compressor not working maybe you need charge.
Jul 16, 2014 | Sunpentown WA-1210E Air Conditioner
Ac is working fine on cool then it goes to fan and the air aint cold anymore
Fan mode only moves the air around the Room it will not cool make sure your on a cooling only setting
Jul 03, 2011 | Sunpentown WA-1200E Air Conditioner
The unit just quit working. The panel lights work, so power is to the unit. If I power off, then on again, the FULL light comes on and then goes off in a couple seconds. No cooling, no fan, NO ICE!
I couldn't find much information about this unit on the net. What I think it might be is that the sensor or control board that responds to the sensor is failing, and, thinking the ice is made, turning off. On this site, in the first review, someone mentioned something being loose inside the unit and just needing tightening, so perhaps that will be a clue:
http://wize.com/reviews-air-conditioners/sunpentown-wa-7500m/page-4
Good luck, hope this helps, and thanks for using FixYa.
Sep 12, 2010 | Sunpentown SPT IM-100 Portable Ice Maker,...
Need instruction manual for Sunpentown WA-7500M
You can get the manual on the link below I hop it will help you.
http://www.sylvane.com/images/productpages/sunpentown/manuals/WA-7500M.pdf
Good Luck and please rate 4 thumbs up for the free answer
Jun 19, 2010 | Sunpentown 7500 BTU Portable Air...
My Sunpentown WA-1220E portable air conditioner is not working. Comp light is flashing (red light). Any idea what could be wrong?
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Jun 28, 2009 | Sunpentown WA-1220E Portable Air...
Why is my sunpentown WA-1210H portable AC not blowing cold air anymore?
May 10, 2009 | Sunpentown WA-1220E Portable Air...
Heating & Cooling Logo
97 people viewed this question
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Pete Norton
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
