Question about Video Game Consoles & Games
Connecting PS3 to LG RZ32LZ55 TV
Trying to connect new PS3 to my LG RZ32LZ55 tv but just keep getting blank screen, can you help me please?
SOURCE: PS3 - HDMI to SD change issues
While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.Good Luck!
Posted on Sep 16, 2008
  • 7 Answers
SOURCE: no sound from ps3 to home cinema via an optical cable
If you have not run the set up you will need to, however I'm guessing you did because you would have had to make some changes to the settings to get the image to come up on the screen but without being physically at your location I can just guess.
In order to view your PS3 in full 1080p you need the HDMI cable which you already have. If you have not gone into your video settings then you are not viewing via the HDMI cable and you will need to to get things working right.
In order to view via the HDMI cable you would have had to had both the standard PS3 interface cable that comes in the box (the one that goes from the PS3 to your tv with the composite video (yellow) and the left and right audio (red and white) and the HDMI cable pluged into your PS3 and your tv at the same time. then you turn on the PS3 making sure your TV was set to whatever imput the composite and left/right audio is pluged into (typically VIDEO 1,2,3 ect.) and enter the menu, go to the settings and then down to your display settings and change it to HDMI, the image should then leave the screen (because it switched to HDMI) you will need to have your TV remote handy for this because you will need to switch sources on your tv to HDMI 1,2,3 ect, which ever one you have it pluged into. When you have switched to the right HDMI imput there should be an on the screen that is counting down and asking you if you want to accept the changes. Select yes and Move on through the settings selecting the maximum resolution your tv is capeable of
720, 1080i, 1080p) which can be found on the box the tv came in or somewhere on the tv or manual. While running this settings change it should ask you the audio source you are using make sure you select Digital Optical and that it is pluged in to you PS3 and your reciever. Once this is all done you can remeove the standard PS3 hook up that came with the box and put it away you wont need it any more, unless you move the PS3 around and the tv you move it to does not have HDMI in which case you will have to change the settings before you move it back to the standard cable or you will not be able to see it displayed on the tv sceen you move to and it will be impossible to run the settings.
If you have already done that and just want to verify that your source for audio originating from the PS3 is digital optical you can check that in the same settings menu under audio settings. Then make sure the reciver is on and set to whatever imput you have the cable pluged into and you should be good to go.
If all that I have described has been done already then the audio cable could be bad or the problem lies internaly with the PS3 or the reciever.
Good Luck hope this helps
Posted on Oct 04, 2008
SOURCE: PS3 won't connect to TV with component video.
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
Posted on Feb 01, 2009
  • 10 Answers
SOURCE: initial set up of PS3. initial set up screen not displayed
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Posted on Apr 20, 2009
SOURCE: PS3 start screen will not show up on my TV
I had this problem before. I messed with the settings on my PS3 and My TV until the settings matched. My PS3 would show the home until I loaded a game. I turned off then on my PS3 to get to the settings. My TV manual had the types of videos it supported so I went with the second to highest setting it supported and it worked. Hope this helps.
Posted on May 29, 2009
I hooked my PS3 to my HDMI cable to get a better visual screen display for my HD movies and games, but display screen went blank and I cant get the commands menu screen, how can I get the menu commands...
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Jun 16, 2012 | Video Game Consoles & Games
    Scart signal
    check the tv mode av1 av2 and pal settings
    Sep 05, 2008 | Televison & Video
    How do you connect the Virgin VHD box to LG RZ32LZ55 TV for getting HD and also the audio. For the audio the V HD box has a optical audio port and a test port ( i am not sure it works!). The TV has a DVI...
    All you need is an hdmi-dvi adapter. You will also need a component audio lead to plug into the mini(3.5) jack socket on the tv as dvi does not carry sound. You will need to initially use the scart to set up your tv for hdmi as the menu can only be seen via the scart until you set it up.
    Jul 24, 2010 | LG RZ32LZ55 32 in. HD-Ready LCD Television
    HOW DO I CONNECT A SKY HD BOX TO MY HD READY TV IF THERE IS NO HDMI CONNECTION ON THE TV ?
    Use the SCART, it has Component Video connections that are capable of carrying HD signal at high quality.
    May 24, 2010 | LG RZ32LZ55 32 in. HD-Ready LCD Television
    I have a new ps3 slimline,cant get a connection t my samsung HDTV
    What you need to do is use a different tv or scart/av cable first, go to settings and reduce the resolution its because the tv cannot handle such a high res, if this dosent work, please post back, Regards
    Dec 25, 2009 | Sony Playstation 3 (PS3) Console
    Im trying to get my ps3 to connect with another tv
    turn off ps3 till the red light is on the machine then you need to hold down power button to turn on until you hear a beep.
    make sure a hdmi cable is not connected at back of ps3.
    Oct 27, 2009 | Sony Playstation 3 (PS3) Console
    Connect tv to cable box with hdmi lead
    You will need an HDMI to DVI cable which are available in the shops, even ASDA has one but I don't know how good it is. Or you can buy an adapter that will plug into one of the ends of the HDMI cable and then plug into the DVI socket at the back of the TV. The DVI input is video only so you will need audio leads for sound. These will connect from the output of your source, say, blue ray or sky HD (Left and right audio sockets ) to the audio L/R at the back left of the TV (on the block next to the three component video connections and s-video connections)
    Oct 03, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
    LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
    Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
    Try different settings.
    I hope this helps.
    Mar 28, 2009 | Televison & Video
    No picture but sound is still there
    The main display driver board, part of the driver board power supply, and or the lamp supply, or the lamps themselves could have a problem. In some cases the LCD panel itself may have a failure.
    The best solution is to take the set to an authorized service rep who has spare working boards and modules to try. This way he will be able to tell you exactly what is involved to service the set.
    If the set is out of warranty it will be expensive to service.
    Jerry G.
    May 27, 2008 | LG RZ32LZ55 32 in. HD-Ready LCD Television
    Video Game Consoles & Games Logo
    83 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
