Question about Jenn-Air JED8430 Electric Cooktop
Burners not working but fan is
We had our countertops replaced and the gentlemen dismantled the cooktop without marking the wires. from the wall I have black,white & ground. From cooktop I have black,red,green,white.
I put the black to black, white to red and ground to green/white.
Is that correct
    Novelist:
  • 161 Answers
Are you sure that is the proper wire from the wall? What you are describing is a 110 volt circuit. THis cooktop should be connected with at least #10 wire and fused at 30 amps. You should have black red and at least white with possible bare ground wire. Assuming somebody used the wrong wire during original install job, you have it connected right. Please replace with heavier wire if it is not #10 Or at least make sure it is fused at no more than 20 amps if smaller wire. (You may sometimes blow circuit breaker if all burners are used on high at once) Use a volt meter and check voltage. If this is a 220 volt circuit you should have 220 volts between black and white and 110 volts from either one to bare ground wire.
Posted on Jul 07, 2008
One of the electric burners on our induction cooktop is misfiring and making noise. Who can fix these things? Is it better to buy a new one?
I recommend to buy a new one, induction cooktop prices have come down a lot and there are good ones available for about $1000. FOr me, the only problem with putting a new one in was the hole in the countertop was too small for the new cooktop (Viking has a smaller hole requirement than most other cooktops). So be sure to measure the hole in the countertop before you buy a new one so you can buy one that fits.
Mar 16, 2015 | Viking Cooktops
We have a whirlpool gas cooktop, Model SC8720EDB, Serial FMG1005626. When the left two side burners are lit, either one or both, the suction fan automatically cuts on. When the right side burners are...
It does this by design. It is a safety feature on this model because it was designed to have a gill module on the left side. I don't know if you can change it without replacing the two left control valves with valves like it has on the right burners.
Nov 24, 2010 | Whirlpool 30 in. SC8720 Gas Cooktop
One of the knobs will not turn at all in either direction. How can I get it to turn?
The picture shows a drop in glass cook top (electric) You have to pull the top, disassemble it from the bottom and replace the switch. Most switches have five wires on them L1 L2 which are your hot 240v, h1 h2 which go to the burner(dual burner switch has h3 h4), and p is the pilot. Terminals are marked, just change one wire as you go or mark the wires as you change the part. Make sure your house breaker is off, no power to unit when working on it . Be careful of the glass top when working on it
Feb 24, 2010 | Jenn-Air JED8430 Electric Cooktop
GE Cooktop drop-in model # jgp328bec2bb - how to take apart the cooktop,I need to replace the spark ignitor switch harness.
Turn off the gas,unplug the power.
Take the cooktop out of the cutout and support it on the countertop.
Remove all grates and valve knobs.
Remove all screws from the valves and the burners.
Remove the burner base plates.
You may have screw on the side holding the top to the base,if so,remove these too.
The top will separate from the bottom exposing your parts.
Feb 11, 2010 | GE 30 in. JGP328 Gas Cooktop
Just installed a new Jenn-Air Model JED8430. Burners work well but fan will not turn on. Two black wires and a ground coming out of my wall....presumedley no neutral. Any suggestions
I suspect that the two black wires were attached to a wall switch or a wall times, along with the ground.
Check to see if you have a hot wire there. then temporarily wire the two black wires together and see if the fan comes on, i believe it will.
Jun 13, 2009 | Jenn-Air JED8430 Electric Cooktop
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Mar 17, 2009 | GE 30 in. JGP326 Gas Cooktop
I can not separate the glass cooktop from the granite surface.
alot of installers will use a silicone glue to "seal" the unit to the countertop. what happens is that means you cant get it out without cutting the glue off first.
it could also be that the unit is very tight in the countertop.
also did you remove the "hold down" screws from underneath the unit first??? there should be a screw on each side below the unit.
one more thing... do you have a gas line under your counter? if not be sure you can get a gas line to it before you try to remove the old unit. most homes have a finished ceiling under the kitchen and it would be almost impossible to install a new gas line if its not already there.
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
I need to remove my Whirlpool Gold ceramic cooktop.
the safest way for a home owner to do this is turn the main breaker off to the house that is the safest way. Then poll the cover plate off the box in th wall with the two screws. not the screws on the round conduit. Then pull out the wire nuts that hold the wires together and un screw them to separate wires I would label them so you know what ones went together. After top is in just reverse the proses above.
Dec 14, 2008 | Jenn-Air JED8430 Electric Cooktop
JED8430BD has 3 wires no ground. Wall has 3 wires including ground
I think the white on the cooktop should be on ground.
cooktop wall
Red White
Black Black
White Ground
Sep 04, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Apr 15, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
111 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
