Question about LG LD65EL Dehumidifier
LG LD65EL Dehumidifier doesn't work properly
Sometimes the unit will run but not condense moisture for days - reversing valve actuated? Sometimes the compressor runs with no fan. Sometimes the fan runs with no compressor - condensor relay problem or thermister? After shutting the unit off for an hour, it may start to work properly and then after a few hours, run but not condense. The basement is about 68-70 degrees and up to 75% humidity when the unit fails to operate. I have cleaned the filter and the coils are very clean.
  • 1 more comment
  • dhmumy Jul 02, 2008
    Very long wait. I'll have to come back. Danny
  • dhmumy Jul 08, 2008
    Thank you. The dehumidifier is set for 60% which kept the room at 50% when working properly. Now, the fan and compressor both run but after a short time the cooling ceases and no water is condensed. Overnight the humidity can reach 65% with the unit operating.
  • dhmumy Jul 10, 2008
    Tech101, Thank you. I have contacted an LG repair facility. Chris0775 and I had a live chat a few days ago.
    Novelist:
  • 121 Answers
What do you have the humidity level set at on your dehumidifier? The average is 65%. Make sure you do not have it set at 75% because if you do this could be causing it to keep the humidity so high.
Posted on Jul 08, 2008
  • Justin Jul 08, 2008
    You may also want to check and make sure the timer option is not set. There is an option for 2 hour and 4 hour operation. It will then run for 2 hours on and 2 hours off or 4 hours on and 4 hours off depending on the setting. I do not use this setting on my LG dehumidifier. If you do not have it on timer and the coils along with the filter are clean I would recommend calling LG because they back this model with a 5 year warranty. They usually offer 2 options:
    1: Have a local repair shop fix the dehumidifier and they cover the bill.
    2: They will process an RMA and they will mail you a return shipping label. Once your model is recieved they will send you a replacement.
    Make sure that you have your reciept to show it is still under warranty. I see you rated my solution as thanks for trying. If you found this solution helpful I ask you to please reconsider the rating. Thanks - Tech101
  • Justin Jul 10, 2008
    Hey Danny,
    I'm glad that you found this helpful. Again I was wondering if you could please reconsider this rating. Thanks - Tech101
Electronic dehumidifier is ON and has been running for four days in a humid musty basement but there is no water in the bucket.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 23, 2011 | LG Goldstar LD65EL Dehumidifier
The unit runs continusly and no water comes from the hose
heatman101
Sep 23, 2010 | LG LD65EL Dehumidifier
It seems as if the unit makes the room warmer. Is this normal?
Yes the heat is a byproduct of the compressor running....there will be a slight overall heat gain...this is very normal and nothing to be concerned about....the dehumidifier passes the air over a cold coil to pull out the moisture but also discharges the heat into the room...so... the net result is heat gain in the amount of electrical energy the dehumidifier is using...
heatman101
Jul 27, 2010 | LG Goldstar LD65EL Dehumidifier
CONDENSATION PROBLEM
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 15, 2009 | LG LD65EL Dehumidifier
The coils frost up for Kenmore dehumidifier model 580.53701300 even the temp is > 70. the fan works fine. there is a few water in the water bucket. the humidity> 65%.
check the drain tube for blockage, maybe run a small rubber hose to clear out blockage so condensation can drain freely. Worth a try worked for me
May 03, 2009 | LG LD65EL Dehumidifier
Dehumidifier runs but does not condense water.
It sounds like an issue with the control bord. This dehumidifier should have a 5 year warranty through LG. You will need to have this serviced. If it is under warranty by LG they will either refer you to a local repair shop and they will pay for the repair or they will replace it if you do not have a repair shop in your area. Call them and explain the problem to them. Make sure that you have your reciept. Here is the contact information for LG:
Toll Free Phone Number: 1-800-243-0000
Email: customerservice@lge.com
Keep me posted. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Jul 05, 2008 | LG LD65EL Dehumidifier
Unit runs a lot. Doesn't condense much water. Sometimes fan runs alone, sometimes compressor runs alone.
You may also want to check the coils and make sure they do not have dirt or dust on them. If they are clean you may have an issue with the refrigerant level which will cause the coils not to cool properly. For that you will want to contact LG. There could be an issue with the compressor also. LG backs alot of their models with a 5 year warranty. Contact them and let them know about your issue. Make sure you still have your reciept. Here is their contact number:
1 (800) 793-8896
Jun 27, 2008 | LG LD65EL Dehumidifier
Puts off a lot of heat
Additional heat from a dehumidifier should only be the electrical heat generated from the compressor. This is due to the fact that the cooling coil and condenser coil (hot bit) are normally located next to each other with a common airflow so the heat generated should be minimal. Hope this helps.
Aug 16, 2007 | LG LD65EL Dehumidifier
Vertical draining
Water only runs down hill. To accomplish your task you would need a small condensate pump to get the vertical lift to transfer to your sump. as an example "http://www.hartell.com/corp/details/0,,CLI1_DIV32_ETI3740,00.html"
Aug 09, 2007 | LG Goldstar LD65EL Dehumidifier
LG Dehumidifier Not Working
the freon has leaked out, must be replaced.
Jun 05, 2007 | LG LD65EL Dehumidifier
LG LD65EL Dehumidifier Logo
786 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
