Question about Microwave Ovens
Danby microwave not heating
My Danby DMW104W will not heat anything up all of a sudden. It was working fine. Everything else works, lights, fan, timer, ect. But nothing comes out heated. Any suggestions Please?
  • William Miller
    William Miller May 11, 2010
    Does the turntable come on when you try to cook?
Yes the turn table turns, everything works, but no heat.
Posted on Jul 07, 2008
My danby microwave is suddenly stopped heating. it's now useless
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 25, 2011 | Danby DMW139 Microwave Oven
I have the danby designer Mod DMW162W-ORT that won`t heat at all but everything else works. Hums a bit louder but will not warm.
The Magnetron in your unit is no longer resonating properly. The Magnetron produces the microwave frequencies and when it resonates properly, it will provide the excitation to heat your item(s). As well, the diode that accompanies the magnetron needs to be replaced as well. Should it be under warranty, take it back. Out of warranty? Have an appliance tech repair it (usually around $175) or get a new microwave.
This is typical for most microwaves. No such thing as quality any more.
Apr 12, 2011 | Danby Microwave Ovens
The microwave shuts off after 10 minutes and takes 30 minutes to come back on. Help!!!
It indicates the magnetron is getting to hot "that heats the food" when that happens the thermal fuse opens to protect the magnetron from over heating and shuts it down and waits until it is cooler before it resets. The other problem could be the fan not working or not properly that blows on the magnetron, it helps keeps the temperature regulated so it can run hard. If it turns out the fan is fine, then the magnetron is slowly breaking down until it becomes unusable, which means it will need to be replaced "pricey" or buy new "probably cheaper"
Jan 20, 2011 | Danby DMW139 Microwave Oven
Microwace buttons suddenly stopped working. Only
Your membrane keypad is failing.
Contact Danby Customer Service US / Canada
If you;re not from the US or Canada, consult your owner's manual or the dealer you purchased it from to contact Danby to find find your nearest Danby servicer.
Jan 14, 2010 | Microwave Ovens
Dmw104w - how do I set the clock
hello. push the clock button and then put in the time using the number keys, THEN push the clock button a SECOND TIME to make it work.
Nov 18, 2009 | Danby DMW112 Microwave Oven
Danby microwave does not heat food and makes loud constant noise
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
Nov 06, 2009 | Danby DMW112 Microwave Oven
My microwave wont heat anymore worked on tuesday model # dmw104w
Click on the link below to view your owners manual. Just copy and paste into your web browser.
http://www.danby.ca/cms/uploads/products/en_manual/DMW104W_EOM.pdf
Check out this link below for notes on the Troubleshooting and Repair of Microwave Ovens http://www.repairfaq.org/sam/micfaq.htm
Sounds like you have a short somewhere. How old is the unit? Let me know how these work for you and if I can help you out with anything else.
JimmyC
Oct 02, 2009 | Danby Microwave Ovens
Danby Designer microwave (with exhaust fan mounted above stove) stopped working suddenly. Lights are on and microwave sounds audible but no heating of food kept inside.
With these symptoms I would suspect a bad magnetron or a loose connection at the FA terminal of the magnetron.
I would suggest you contact Danby customer service o locate their nearest authorized servicer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 08, 2008 | Danby Microwave Ovens
Danby micro: turns, lights, doesn't heat
Heating for that long may have damaged the magnetron.
I would suggest you contact Danb for assistance:
http://www.danby.com/page.asp?code=2
Dec 05, 2007 | Kenmore 80412 Microwave Oven
Microwave Ovens Logo
1,058 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
