Question about Garmin nuvi 250 GPS Receiver
Battery Icon. The unit (Nuvi 250) won't display the battery icon that is supposed to be on the top right corner of the screen. It powers up fine though. How can I get it to show the icon?
  • 2 more comments
  • Albenarth Jul 02, 2008
    It's okay. It's just after appearing.
  • pellop Nov 24, 2008
    I seem to have the same problem - on the top right of the screen I only have the time, on the left there are the signal bars and no battery icon anywhere!
    Anyone knows how I can get it to display?
  • justin173 Dec 23, 2008
    I also have the same issue my unit will also not turn on when not connected to a power supply. It is as if the unit is not recognising that there is a battery in the unit at all.I am assumming that the device will turn on as per normal with or without external power? When the unit is on power there is still no indicator as to if the battery is charged at all and I have a 4wheeler with a dedicated Power fitting so I know that the unit is powering when in the vehicle, the unit also indicates that it is charging when turned off and left in the car plugged in. It is new and I have only had it two days
  • wloh Jan 03, 2009
  • 19,396 Answers
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
See also battery_repair.
Posted on Apr 10, 2009
How to have the battery life show on the screen ?
The battery indicator will only show on the screen in the upper right-hand corner of the screen when the unit is NOT connected to an external charger. When the charger is connected, the unit is running off of external power. The unit has to be running on battery power in order to display the battery status icon.
May 27, 2014 | Garmin nuvi 1450 GPS Receiver
How much time is it to charge th nuvi 215
Typically charging overnight is good enough. Look to see if the battery icon located in the upper right hand corner of the main screen is at a full (4) bars. The icon is divided into (4) bars. The Nuvi 215 is a pretty old unit. If the battery hasn't been changed within 2 years it needs to be. Old batteries can leak and bloat (swell up). They will also not be able to be fully charged and will lose power very quickly. For more information on battery replacement, please see this link:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Mar 10, 2014 | Garmin nuvi 215 GPS Receiver
Garmin Nuvi 260 Car GPS Receiver
When the charger is plugged into the unit, look at the main menu screen. If the charger is working correctly, the green battery icon in the upper right-hand corner eill go out. If the charger is plugged in and there is a light lit on the charger but you see the green battery icon in the upper right-hand corner of the screen on the main menu, then the unit is on battery power and the battery is not getting power from the charger. Common problem with these units are loose rear USB ports. More information can be found here:
http://www.sharc.net/gps_charger_repair.htm
Sep 06, 2013 | Garmin nuvi 260 Car GPS Receiver
Show charging symbols
Your question was posted under the Nuvi 680 GPS, so I am assuming this is the model that you have.
On the main screen, you will see a green battery status indicator in the upper right-hand corner of the screen. The battery is divided into 4 parts. Each part represents 1/4 power. So if you have one green bar, that indicates that the battery has 1/4 of power left. If there are 3 bars, that indicates that there is 3/4 power left.
When the unit is charging, you will see a yellow lightning bolt appear over the green battery status icon.
When the lightning bolt is not there, this means the unit is running off of the battery.
When leaving the unit to charge, press and hold the power button until you see that the screen says Charging Battery. A few seconds later, the screen will go blank to save energy.
Pressing the screen again later will either say Charging Battery or Battery Charge Complete.
Mar 26, 2013 | Garmin Nuvi 680 GPS Receiver
Honeywell DT200 thermostat is not responding to any buttons pressed. Display is showing small flame icon on left of screen and what looks like a battery in top right hand corner. Any suggestions?
The thermostat is calling for heat, and the battery icon means that the batteries are low and should be replaced. If the thermostat is wired to run on battery power alone, replacing the batteries usually corrects this problem. Hope this helps! Jim
Jan 29, 2011 | Honeywell Heating & Cooling
Battery charge
Power up your unit with nothing connected to its USB port. The battery status icon should appear at the top of the main screen.
Apr 15, 2010 | Garmin nuvi 255W GPS Receiver
Nuvi 1350 randomly shuts down
Hello :
Try to replace the battery . Because I think that the battery is almost at the end of it's life .
If that didn't work , then I recommend you to reset your NUVI .
Here is the resetting method :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
The gps automatically shuts off after few minutes
When you turn the unit on and get to the screen showing Where To?, View Map and Travel Kit look on the upper right hand corner of the display and make sure you see the battery icon all green. If it is not then the battery is not charged
Apr 04, 2010 | Garmin Nuvi 660 GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Garmin nuvi 250
RESET THE GARMIN NUVI Start with the unit off ,: press and hold the corner ( cant remember what corner top/bottom//left//right) tye each one: one at a time while olding the screen down on one of the corners press the power switch to the on position your unit should flash a few times then you sould see the logo apear GARMIN ( I would tell you witch button for sure it was but can;t bring myself to reset everything on my unit at this time)(sry :))
Sep 11, 2008 | Garmin nuvi 250 GPS Receiver
Garmin nuvi 250 GPS Receiver Logo
515 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
