Question about Microsoft Windows XP Home Edition
Trying to launch internet explorer.it gives me error 680.
Cannot launch internet explorer. gives me error 680.
  • 86 Answers
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Posted on Jul 03, 2008
Java download failed
what error do u get when u r lunching internet explorer or firefox? try to download in install google chrome and try
Dec 02, 2011 | Microsoft Windows XP Home Edition
How do I fix Error 306 without having to buy something like WiseFix?
No need to buy WiseFix. Here are some handy troubleshooting articles that have resolved this error (306) before.
Please do this if you have or are using Internet Explorer (browser): - Launch Internet Explorer- Click the Tools menu- Select Internet Options- Click the Connections tab- Click the LAN Settings button- Make sure that that "Use a proxy server for your LAN" checkbox is unchecked- Click OK till you are out of everything, and then close Internet Explorer- Try again in iTunes to load the store
Alternatively, please take a look at:https://support.apple.com/kb/ts3297
or
https://discussions.apple.com/thread/2157649?start=0&tstart=0
Cheers!
Sep 29, 2011 | Apple iTunes
What's your problem? FIX ERROR 306
Please go to https://support.apple.com/kb/ts3297
Look under the heading "iTunes Store loads partially or returns "Error 306" or "Error 10054""
OR
Please do this : - Launch Internet Explorer- Click the Tools menu- Select Internet Options- Click the Connections tab- Click the LAN Settings button- Make sure that that "Use a proxy server for your LAN" checkbox is unchecked- Click OK till you are out of everything, and then close Internet Explorer- Try again in iTunes to load the store
I have recently been getting an error meassge when trying to open emails in Yahoo.com. The message is "Internet Exolorer cannot open the Internet site Http://us.mg4.mail.yahoo.com/neo/launch?......
This error was known in Internet Explorer 7 (this may be caused by both browser and website), and the solution is simply in updating your browser
you can always download a free version of Internet Explorer here -- http://windows.microsoft.com/en-US/internet-explorer/products/ie/home
Jul 03, 2011 | Yahoo Mail
An unknown error occurred (306)
http://discussions.apple.com/thread.jspa?threadID=2152912&start=90&tstart=0
or:
Okay, I found the solution when running CA Security Center for me. You need to open your Parental Controls - Advanced Settings. In the user/default tabs select Web Filters. The select "Custom List" under the allowed section. Then add the following sites individually: itunes.apple.com, ax.itunes.apple.com, albert.apple.com Be sure to select the checkbox to allow the entire domain. Then restart iTunes.
Mar 07, 2011 | Apple iTunes
Will not let me open. I get an error message when I click on messages. To open I have to go thru my yahho
Let me understand your issue. When you are logged in Yahoo messenger and you receive an email, you are not able to open it and it gives an error message to launch ?
If so,
Follow the below instructions to resolve the issue
You will have to set Internet Explorer as your default browser
You will have to Clear/delete unwanted files and cookies stored in your PC memory downloaded from Internet surfing. ( there is no harm in deleting the cookies/files downloaded while surfing )
1. Open Internet Explorer
Click on Tools from menu bar ( or you will find it on right side corner of Internet Explorer )
Click on Internet Options ( a window opens )
Under General Tab - Click on Delete button
Or
you may find Delete Files and Delete Cookies
Delete the files and cookies and click Apply button
2. Open Internet Explorer
Click on Programs Tab from top
You will find Default Web Brower
Click on the option Make Default
Click Apply button below and Click ok
Next time try to open the mail once you receive and it should open from the click without you opening yahoo mail page.
Nov 02, 2010 | Yahoo Mail
Unknown error occurred (306)
some people have been doing this
do a google search for "itunes error 306" for other discussion boards on the topic, seems to have occured after an itunes update conflicting with OS (go figure right?)...hope this helps =)
Feb 04, 2010 | Apple iTunes
I get this error everytime I try and use IE I can't use IE it wont launch runtime error! program:c:\program files\Internet Explorer\iexplore.exe this application has requested the runtime to...
you can try to re-install IE, go to control panel then open Add/Remove programs, on the left side of the Add/Remove programs applet click Add/Remove windows components, under Components look for internet explorer then uncheck it then click next, IE will now be uninstalled. Then reinstall it, just like previous process on Add/Remove windows components put a check on internet explorer then click next.
If this wont solve the problem, you can try a third party browser like firefox, download firefox on this site: http://www.mozilla.com/en-US/firefox/, after downloading firefox just double-click it then just follow the installation.
Jul 23, 2008 | Computers & Internet
Internet Explorer won't launch after a hard reset
Is it picking up a good IP address? Are the access points encrypted? You would need to set up the Wi-Fi on the PDA to the specifications of the WAP. if Internet Explorer is not loading, I suspect that there is a problem either with the image in ROM or else with the part of the RAM which is used to hold user data for Internet Explorer. Have you recently upgraded the ROM? The upgrade may not have worked properly perhaps. Maybe try a reflash of the ROM image. Do you get any error message or does the operating system go round in a loop and never come out?
Sep 14, 2005 | HP iPAQ H5450 Pocket PC
Microsoft Windows XP Home Edition Logo
519 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
