posted by cpacpayroll on Jul 02, 2008
for the kenmore elite oasis he top load washer, what does the error code DL mean and how do i fix it
Solution #1
posted on Jul 26, 2008
i have a kenmore elite oasis top loading washer. i can shoose the setting and press start and it will think a bit then give codes, and sometimes it will start to run water in the soap then stops. the codes are SR, CE, L5, LD, and, OB. th load isnt unbalanced though i checked thata over and over, and the drain hoses and all that looks good. the L5 code is not in my nmanual andyone that can help i would greatly appreciate it
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE WBSR3140DW Top Load Washer
GE WBVH6240F Front Load Washer
GE WJSR2070B Top Load Washer
GE Appliances 3.2 cu. ft. Super Plus Capacity Washer
GE 3.5 Cu. Ft. Capacity Commercial Washer with Stainless Steel Basket, WNRD2050DWC
Bosch 3.81 cu ft Nexxt 500 Plus Series Washer - WFMC530 1UC / SUC / CUC / WFMC530CUC - Champagne Du
Bosch Nexxt® 500 WFMC3301 Front Load Washer
Can you Help with these Washing Machines problems?
Repair Service
Find Washing Machine Repairman Near You:
