Question about GE Profile Harmony DPGT750EC Electric Dryer
GE DPGT750 not heating
I have a GE DPGT750 electric dryer that doesn't heat.  It was diagnosed and it is in fact the heating element that needs replacement.  I have the part, just need to replace the old one.  Do you have the repair or other manual which would help me do this?
Please let me know and thank you for your help.  laszlowindhoffer@gmail.com
Laszlo
  • 1 more comment
  • brdj May 09, 2009
    I too have a GE Profile Harmony Electric dryer that won't heat. Also, the blower isn't working. The drum is spinning and there is power to the control panel.
    I've been able to remove the control panel and the dryer top, but I don't know how to get at the blower and heating elements from there.
    Does anyone know if there is there a service manual available?
    Thank you
  • wlagoe May 24, 2009
    My washer and dryer were hit by lightning a year ago and GE replaced the motherboard (? - control panel card) in each, however, I remember my dryer drying my clothes better than it does now. I seem to have to keep adding more time to ensure that the clothes are dry even with the sensor on.
    The GE repairman never checked beyond the main controls to ensure nothing else was amiss. Am I remembering wrong or can it be that something else was hit?
  • InkMing May 11, 2010
    Looking for the repair manual as well. ddobryns at fedsched.com
    Thanks!
  • 770 Answers
Check your email this manual will take you step by step thru the repair
Posted on Jul 08, 2008
  • Duke Ho Nov 03, 2011
    Could you please send me a manual how to replace blower. My dryer of this model has no air blow out of the duct behind the dryer. dukeho@hotmail.com
    Thanks Gary Davd
  • 54 Answers
No repair manual and is a job to replace. You have to remove the control panel, dryer top, top heat shield, dryer front, front drum support, belt, and then the drum in that order to get to the heater. I have been working on these since they have been out and have never changed a heater in one, They just dont burn out. Unplug the dryer and take the access cover off where the power cord attaches to the dryer and make sure the wires are not loose or burnt.
Posted on Jul 04, 2008
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Dryer doesn't heat
Is it electric or gas? Most likely u have a blown thermostat or fuse. Could also be a bad heating element if electric. Or bad solenoid coils if gas
Nov 15, 2011 | GE Spacemaker Washer and Dryer Electric...
I have a GE DPGT750 Gas Dryer. The dryer will not heat up. Air is blowing out of the exhaust outside. However, the air is cold.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | GE DPGT750GC Gas Dryer
What do I do if my dryer runs, but does not heat?
Hello my name is Heath the problem is probably a bad heating element. If the dryer runs but does not heat then the heating element is bad and will need to be replaced.
Apr 07, 2010 | GE DDC4400S Electric Commercial Dryer
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
My ge gew9250p dryer heating element is needing replacement what is a good part number for this
Hello there:
this should help you out ok
See Part # 14 on diagram.
or
See all parts for this section / diagram Heating Element (11" long x 5" wide) (Heater Element) This heating element fits later model Whirlpool/Kenmore brand electric clothes dryers. Each of its two terminals measures 5/16 of an inch, while the unit itself is approximately 11 inches long by 5 inches wide. This element carries 5200 watts and 240 volts. Appliance Help Part Number AH344597 Availability: In Stock Compare At: $56.32 Your Sale Price: $46.93 You Save: $9.39 SALE PRICE:$46.93 -->
Nov 22, 2009 | Whirlpool GEW9250P Electric Dryer
Hello, My GE Profile dryer model DPXR47EW0WW serial TV771164A has stopped heating. What should I be checking? Thanks, Bob
open it up - take the drum out - the heating element is there - check the wire for breaks - then there are three fuses - if the heating element does not have any breaks - take the fuses to a parts store and have them checked.
Jan 24, 2009 | GE Profile DPSB619ED Electric Dryer
How do I test for bad thermastat or heating element on GE dryer
well the fact that hte heating elemnt is glowing tells me that all the thermstats are working, i would check for a blockage/restriction in the venting. looking at te diag, its possible that only 1 of the 2 coils for the heate are actually going on, check the coils for continuity( may be a small break that separates when gets hot)
Dec 07, 2008 | GE DCSR483EA Electric Dryer
Dryer not heating
Your heating element is probably blown. It's not easy to replace it, but give it a try and stick with it. You can do it. Open the dryer door and look upward. You should see the screws holding the top front in place. The back usually slides out,or has two screws, one on each side on a piece of metal sort of like a hinge. Take off top and front, and then remove the drum. You will see the long round element in the rear. It looks like a long spring. Do not take the spring loose from the housing. The element comes with a new spring assembled to the new housing.. There are also several small thermistors in there that look about the size of a quarter. They should all be "closed" so that current can pass thru. Some thermistors look different. They look like the sharpened end of a pencil and are about an inch or less long. Pointed at one end and a wire coming out of each end. Replace this before replacing element. Or if you have a small volt/ohm meter, measure the ohms of the element. They should be quite low-----------300 ohms or less--------probablyi much less. If "open", then the element is bad. keever
Mar 06, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
981 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
