Coleman Rechargeable Spotlight Logo
Posted on Dec 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The light fell and now the light doesn't work at all and there is a rattling noise like when a bulb is busted. How can I find and replace the correct bulb or might it be something else?
Anonymous
Level 2:
New Friend:
  • Expert 40 Answers
  • Posted on Dec 18, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
40
Questions
Helped
9874
Points
130
You'll need to dis-assemble to see exactly what broke. Most of the time, it is not worth fixing since it was dropped, something else will let go in the near future. Sorry.
You'll spend less $ buy buying a new one.
Electrics prob. with indecators lights and hazerds lights
check all the bulbs theres probably more than one bulb busted
1helpful
Fell into the Halfords trap of buying A replacement rear stop and tail light that was not the correct one despite their technical directory saying it was. Now got no tail lights on one side. Is the...
has to be a fuse sometimes they are wired diagonally so you will always have a ligt front and rear check see if front light out too if so try locate fuse .some of them bulbs have a staggered pin on them will only go in one way if the bulb combines side light wit brake light goodluck
I have a 2003 Mitsubishi Lancer. A few weeks ago when I turned on the air I could hear like a rattling in the fan. Now the air will run for a little while then slowly weeken until it just stops. What could...
It could be your aircon blower that's busted. I had the same issue with a 97 Lancer. It was the motor of the blower that was defective so I had it replaced. Never heard the rattling noise and the A/C works perfectly fine after the replacement.
HTH and good luck!
What does a burned out lamp look like
Normally if the bulb is burned out the bulb will have broken bits inside the bulb itself, AND WILL NOT LIGHT UP, and it will rattle, If the bulb doesn,t light up, as seen through the cooling vents, then replace the bulb.
Brake lights don't work, the cruise does, all the
1. check the brake light bulbs. if busted replace. 2. check the brake light switch near the brake pedal. make sure the wires are fitted correctly. 3. check the fuse. if busted replace.
Lights from the refrigerator where flickering and rattle noise
you need to replace the electronic control board $80.25
Neptune gas dryer rattles sporadically when running.
do you fell it rattleing alot? Its can be the rollers are very worn and need to be replaced or the center of the rollers need to be greased up. hope this helps...
1999 Nissan Altima GXE Turn signal problem
you have a busted bulb, your hazard may be working fine but the bulb is double contact so one part is working and the other is not. just check which bulb is busted.
Couple of problems
does the car run ok when running [or does it use more gas than usuall does it idle ok] noises coming from your intake that are loud is normally signs of an inlet valve burned . you say one brake light works the other doesn,t but the the brake light stays on all the time first of all you need to fix the brake light that is not working i presume when you say you checked the bulb on the light that is not working firstly is it the correct bulb and is it in properly as they are handed and even if it looks ok check it by replacing it with the bulb out of the other one you know that works if thats ok fine if it still doesn,t work your going to need to check that there is a live feed to it and a ground but needs this sorting first. for brake light to be on all the time it must have a live feed so the favourite is going to be a faulty brake light switch take the wires off this and see if the light goes out it should if not your going to have to check the wiring from the switch to the rear lights yates210456
I have an alignment problem with colors and i've found a little mesh screen
yr previous buld is it burn out or explode ?
if explode might be the tiny glass neeed to service (cleaning)
please do a tilt correction
do manually
Top Coleman Camping, Backpacking & Hiking Experts
Bob C
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
