Make sure that the Block WAN/Anonymous request is also disabled on the router.
Where do I find this option.
You will see on the setup page of the router under the Security tab. Do you know how to access the setup page of the router?
Have you tried opening the ports on the router for your pc anywhere?
This is because the router has a builtin firewall on it. For applications like pc anywhere port forwarding or port trigerring should be done on the router so that the router's firewall will allow the PC Anywhere software to freely go in and out through the router's firewall.
In your case you will need to enable port forwarding. I have here a link on how to setup port forwarding on your router. click here.
I hope this one helps.
The Block/WAN was not checked so it was not causing the problem. I just see a Black screen when I am connecting to the host computer which is behind the router.
On the Host computer, the PC Anywhere program is Waiting For Connection, so the host computer is not seeing the remote.
Yes as per the instructions that I found.
Still don't know what I am missing. The computer is I am trying to connect to is 200 km away. I can connect to it via the phone line, but before the router was added I could connect to the computer without a problem.
