Computer doesn't start with power or battery.
    Scholar:
  • 160 Answers
For solving your problem do the following:
1. Check that the power cable is connected properly
2. See that the switch is ON
3. See that the SMPS is working
4. Check the Voltage coming out from SMPS using multimeter
Let me know that your problem is solved and rate me as Fixya!
Posted on Jul 02, 2008
Acer aspire 5630 doesn;t start. problem with the monitor and the fan any solutions
If the fan is not working, your computer will not start sometime. Try cleaning the fan with hand held vacuum cleaner. and restart the computer. Before you clean the fan, remove the batteries and power cable from the computer.
Oct 25, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
How to repair red screen on asus eee pc sea shell
Remove any discs in the computer.
Hold the power button down until the computer turns off.
Press the power button to turn the computer on. If this doesn't work, proceed to step four.
Remove the battery and unplug the netbook. Wait 30 seconds.
Reinstall the battery and plug in the netbook.
Press the power button for ten seconds. If this doesn't work, proceed to step 7.
Insert the end of a paperclip into the reset button to reset the netbook.
The reset button is a small hole that usually appears next to the USB and other ports.
Windows 7
Create a new Notepad file.
Type this code:
taskkill /F /IM dwm.exe
Save the file as displayfix.bat in the following location:
C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
Restart your computer.
hope this helps
Sep 25, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
HP Elitebook 2530 Pindicator says battery charging but battery not charging
Could be a back power brick or DC jack yes. Power off the computer and remove the battery. With the battery out plug in just the power brick and turn on the computer. If the computer doesn't power on gently wiggle the plug into the laptop and repeatedly hit the power button if it comes on briefly then off again you dc jack is loose. If it doesn't come on at all then its the power brick. If the laptop comes on gently wiggle the plug into the PC. Powers off while wiggling DC jack.
Jul 09, 2012 | HP EliteBook 2530p Notebook
Acer Aspire 7736Z-4088 wont power on
Hi tloechli,
Follow this steps:
1. Disconnect from Power Adapter and remove battery 2. Press Power button for 5 seconds 3. Put the battery back and start the laptop
Note: If this doesn't work check memory and/or mainboard, or bring it to a certified troubleshooter or Computer Technician.
Hope it helps.
Thank you for using fixya.
Oct 05, 2011 | Acer Computers & Internet
The laptop doesn't start but the charger works.
Take out the battery and connect the charger.
Then try to turn on the computer.
If it works, there is no problem with your computer.
After that insert the battery, plug in your adapter and try turning on once more.
If it doesn't work, you need to get a new battery.
Oct 01, 2011 | Toshiba Satellite Pro L300 Notebook
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
When i putu the power cable on, the led light blink once and goes off. the screen is black. no fan is moving or any sound.
You should try to start your computer without the battery installed. If that doesn't work, you should try another power supply. If that doesn't either do the trick, it could be the motherboard causing the trouble.
Jun 14, 2011 | HP 530 Notebook PC
Trying to reboot my hp compaq nc6320 and i cant figure it out, how do i even get the process started
Hello and welcome to FixYa,
Rebooting is simply pressing the power key to turn the computer off.
Wait one minute,
press the start button again and let the computer completely power up.
If you would like to try to 'reset' the computer;
Unplug the computer from the wall,
turn computer over and take out the battery.
Press the power button for one full minute.
Put the battery back in, then plug in the power cord (in that order).
Press power button again and let computer start up completely.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
May 29, 2011 | Computers & Internet
For laptop: Toshiba Satellite A105: My battery won't charge/computer won't turn on when plugged in. No lights show when plugged in. Don't know if it's a problem with the chord or the computer. Don't want...
Start by trying another power outlet.
The power adapter should have its own light. If it doesn't light up then the adaper is bad. Kensington.com sells very inexpensive universal power adapters. You might also find a good deal on eBay.
If the adapter lights up then it may be your battery. Notebook batteries are only good for 2-3 years. If you let them sit for a long time without a charge they may only last 1-2 years.
Vote for this solution if it helps.
Aug 18, 2009 | Toshiba Satellite A105 Notebook
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
