Question about Toshiba 42H81 42" Rear Projection Television
Analog antenna I have an analog Toshiba television. I would like to get a new antenna, but before I buy one, I wanted to know if there is a converter box/antenna combination (a 2-in-1). Thanks!
  • matti1982 Jul 07, 2008
    I need a new antenna anyways- Is there one you recommend? I just use the regular air channels.
    Scholar:
  • 78 Answers
Hi matti1982,
According to the FCC’s dedicated website at http://www.dtv.gov, the same antenna you use right now for an analog reception will likely work well to receive digital channels. I am not aware of a package bundling the two products together, but it is quite possible a retailer could do so. I would check out what the FCC has to say about the transition to digital broadcasting before determining if you will buy a new antenna.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jul 02, 2008
  • Jason Parker
    Jason Parker Jul 09, 2008
    Hi matti1982,
    The best antenna for you depends on a lot of factors, so there would not be any one specific product for me to recommend. What you want to consider are things like your distance from broadcasting towers, obstacles like large trees or buildings in your way, and the location of the antenna itself. If your home has a pretty clear path and small distance to the tower, you should not need a very powerful antenna. If your antenna will be placed downstairs or not close to any windows, you may need some amplification.
    Besides placement, you will want to consider the types of channels you wish to receive. Some antennas are better at receiving UHF, some VHF, and some both. Find out what kind of television reception you need.
    Also, some antennas need to be aimed for a clear signal, while others are omnidirectional. Most ominidirectional antennas require much less fine tuning between channels than conventional "rabbit ears."
    My best suggestion is to speak face-to-face with a home theater specialist who can weigh all of your factors to make an accurate recommendation.
    Thank you,
    Jason,
    Go Ahead. Use Us.
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
I'm trying to hook up an indoor antenna to my polaroid flm-3232 do I need a digital converter box or does the tv have the necessary components?
You have an analog TV, meaning that the tuner in your TV is analog only. You must buy a digital converter to see broadcast Digital TV via your external antenna and it will be attached to the antenna input jack or other jack depending on how it comes out of the converter.
One bit of advice, there is no such thing as a "digital" antenna, they are all analog. Even a 50 year old, outside antenna aerial that you see out in the countryside will pick up the new Digital Broadcasts to be converted by a Digital Converter and displayed on a 50 year old TV.
Oct 21, 2012 | Polaroid FLM-3232 Television
How can I get analog channels to work with DTV without cable
Hello drandald,
what you need is a converter box to convert analog signals to digital. I know there is one in Best Buy (not sure if there is one in your location) but they have one called access digital tv converter. They are about $50 (CAN). You would still need your antenna or however you get your analog signals. The antenna needs to be plugged into your converter box and then the box would need to be connected to your tv. Good luck.
-Joe
Aug 29, 2011 | Zenith Televison & Video
Hello drandald,
Your tv is a digital tv, so you do NOT need a converter box. The tv has a built in digital tuner. But if you have any other older tv's then what you need is a converter box to convert analog signals to digital. I know there is one in Best Buy (not sure if there is one in your location) but they have one called access digital tv converter. They are about $50 (CAN). You would still need your antenna or however you get your analog signals. The antenna needs to be plugged into your converter box and then the box would need to be connected to your tv.
-Joe
Aug 29, 2011 | Zenith Z32LC2D 32 in. LCD Television
During the past year, we've had to buy five converter boxes quit.
My DTA1050 worked OK. Then, after a period of non use, it would not work stating no signal. The antenna tests OK on a digital TV.
These things simply die, and Access has our government money!
Jul 23, 2010 | Insignia Digital-to-Analog Converter for...
I want to know if my Zeineth TV #B32A24Z is analog or digital
This is a Analog set. If you use an Indoor antenna or Outside antenna you will need a converter box. If you are on cable you won't need a box.
May 01, 2009 | Televison & Video
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
How do I tell if my tv is analog
Hi Dru,
Good news, your 42 inch Phillips has a built in digital tuner, all you need is an antenna.
Please post the model of your other Tv and I will check on the tuner type.
I have provided a link to a site that has good info on antenna types and the channels you will be able to recieve.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this was the information you requested and please rate this solution.Lone99star
Jan 25, 2009 | Philips Magnavox 42MF521D/37 Television
Digital to Analog converter...no signal
One of the problems with digital reception is if the signal is not strong enough for the converter box/or built in tuner on a new TV- you will not get any picture at all. If you followed all the directions-and the converter box shows no channels- then you do need a better antenna. I don't know how far you are from the broadcast antenna, but a good rule of thumb is if you live 10 miles away, buy an antenna that is good for twice that distance, or further. They are rated in miles of reception
Jun 23, 2008 | Televison & Video
Toshiba 42H81 42" Rear Projection Television Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
