Question about Vacuums
Vacuum cleaner smells bad
My Vacuum cleaner smells bad. What can I do to stop that?
  • Anonymous Mar 17, 2014
    bad smell new vacuum
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=732502
Generic problem for all Vacuums
Posted by WhyAge on Jul 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Depending on the brand name and model # you should do a few things, try changing the bag and or change or clean the filter depending on what type of vacuum you have, a dirt cup model or a bag system. The vacuum cleaner dealers have Vacuum crystals that can be sprinkled down on the carpet and then you can pup the crystals from the carpet with your vacuum. If not I suggest that you take it in for a good and general cleaning – a lot of times the dirt and dust get built up under the hood and just sits there – especially if you have pets and it is a hard smell to get rid of unless you have it serviced or cleaned. If you have any questions, please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 02, 2008
2 Suggested Answers
Vacuum Guru
  • 78 Answers
SOURCE: My vacuum cleaner brush stopped rotating. Just
Almost certainly you have broken the drive belt. THese machines have a rubber belt that is designed to snap if you get the roller brush stuck on something. The most common reason for this to occur is that you **** up the end of a rug, the curtain or a sock. This will stop the roller but the drive shaft will continue to spin which chews through the rubber belt.
What you will need to do is buy a new belt and fit it on.
Hope this is helpful for you. If it is please take a moment to give me a rating. If you are in Australia and need somewhere to get you miele belt from try nelsonvacuums or VacuumSpot.
Posted on Dec 22, 2010
I started vacuuming and the vacuum motor slowed down, then stopped. I smelled a burning smell. Then I discovered the next day that the bag bottom was wet and falling apart. Sebo X4 model
sucked up liquid goes with the air through the motor
that would cause the motor to burn out
with the current low cost of new vacuums , the repair /replacement of the motor would be close to a new unit
take it to an appliance repair shop and get a proper diagnosis and quote
Dec 02, 2016 | Vacuums
My cordless Dyson V6 animal vacuum filter smells badly, like dog breathe, how do i rid the smell?
Thoroughly clean all parts of the vacuum cleaner with something like Lysol disinfectant.
Jun 30, 2016 | Dyson Vacuums
How do I replace the fuse on a rainbow vaccum?
The D4 model Rainbow has a Thermal Cut Off
This has to be manually replaced. It is attached to the Field 120v D4
If this has blown, then most likely something is causing. The Armature Tall 120v D4 could be going bad.
You can also speak with our technical support team Contact Us
RainVac
Jan 27, 2016 | Rainbow D4se Classic Canister Vacuum...
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
Mar 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
GoVacuum.com
Apr 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Hoover S3639 Windtunnel Vacuum not on after burning smell
how old is it ?maybe the motor went south.take the cover off and see if you see any burn marks ,maybe you can narrow down the burnig smell.i don't charge people for helping i just enjoy helping.314-628-9153
Apr 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=528723
Posted by lcw1 on Apr 20, 2008
Our Hoover Windtunnel has recently started emitting a bad odor when we use it. We recently bought a new house, and the previous owners had dogs, but the carpet was professionally cleaned before we moved in. I have replaced all of the filters and belts to no avail. At this point, I have to remove and rinse off all of the filters after every time I use the vacuum to prevent stinking up the entire house. Any suggestions?
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Hoover U6616-900 WindTunnel Bagless...
Vacuums Logo
974 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
