Dlp tv makes grinding noise cooling fan good - Televison & Video
  • 3 more comments
  • brw7410 Oct 20, 2008
    makes loud humming noise when turned on . lasts a few minutes then fades but not gone
  • Anonymous Nov 25, 2008
    I have the same problem with the HLP5063W. I think it's the bulb cooling fan. how bad is this and can I freplace it myself?
  • Anonymous Jan 27, 2009
    fan is roaring
  • Anonymous Mar 30, 2009
    fan makes a wining noise at times - started after replacing the bulb.
  • stevesss Apr 20, 2009
    I have a 4 year old samsung HLP 4663 46" projection TV and it is buzzing loudly from the cooling fan behind the lamp. Where can I purchase a replacement fan assembly?
5 Suggested Answers
  • 192 Answers
SOURCE: HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Posted on Apr 01, 2007
  • 5 Answers
SOURCE: Toshiba DLP fan noise (52hmx95)
UUUUggggghhhh I have a 1 year old Toshiba 50" DLP rear projection and it had fan noise. It also had a wierd dark spot on the screen that really wasn't on the screen itself. I was taken to a service center and held captive for 2-3 weeks and returned with a new light engine. I thought great! 3 weeks to a month later and bordering on expiration of warranty it starts to make a low screeching sound like a small motor in need of lubricant. The picture jumps all over and resembles a 256 color PC Monitor. The service center comes and picks it up and holds it captive for another 2.5 weeks and says they cannot duplicate the problem. I had even sent them a quicktime movie of it in action.
They drop it off and an hour goes by and off she goes again. Now the longer I leave it on the worse it gets and shuts itself down and sometimes blinks the "light engine" code. Spoke with Toshiba and they are escalating it and should hear back in 3 days... OMG. Kinda off on a tangent, but they do make strange noises.
Did Toshiba get out of the DLP game???
Posted on Jun 17, 2008
golfnfish51
  • 6 Answers
SOURCE: noise from tv
I had the same problem with a 5065. I purchased and installed a new color wheel and that solved the noise problem. The color wheel has a bearing that gets "dry", and when it fails it does sound like a fan bearing.
Posted on Sep 28, 2008
ladywinn
  • 5138 Answers
SOURCE: 50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Posted on Apr 28, 2010
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Recently and occasioally the set makes a sound like a fan hitting something
If its a constant grinding noise it may be a bad lamp fan or a color wheel. But only if your TV is a DLP...
Aug 25, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Toshiba model number 62HM95 62' makes grinding noise
SORRY, This is from the authorized Toshiba parts center:
"The color wheel, lamp fan, lamp fan holder are parts of the LIGHT ENGINE only." It means the wheel is not sold separately and there is not even listed in the breakdown for the set a part number.
A replacement light engine (optical light engine) retails for 456.00 list and is sold on an exchange basis only.
SD TECH
May 13, 2010 | Toshiba 62HM95 62" HDTV
My tv is a samsung dlp 5063w I change de dlp bulb and now is working good but from the back of the tv is a loud noise
Ok look my friend..
first i need to know what type of sound is it. like a click or a buzz?
and then here are 3 suggestions.
first clean your TV with some latex globs and a can of compress air try to do it really good try that...
second. check that all the cooling fans are working just fine!
last one. its your color wheel and you need to change it.
here is a link were you can find the part and not so expensive prices!
http://www.discount-merchant.com/PANASONIC-Cooling-Fan-Set-Cooling-Fan-Set-p/1002171.htm
http://www.discount-merchant.com/product-p/samsung-bp96-00674a-cw-enc.htm?1=1&CartID=0
good luck!
Jan 21, 2010 | Samsung DLP HL-P5663W 56" TV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Tv making noise sounds like projector motor.
Your cooling fan may be collecting lint. If it cannot run freely, you will lose a projection lamp. Just like a clothes dryer, you must have a good clean exhaust exit to assure proper performance!
Nov 29, 2009 | Vivitek V37655 56" DLP TV
Cooling fan motor is making loud humming noise
You will have to pull out the light engine. That will consist of 4 or more screws and disconnecting some plugs. The the whole unit slides out where you can get to the fan housing.
Unless you're mechanically inclined, you should not try it as you could damage the assembly.
I don't know the part number off hand and some of those have newer part numbers as replacement for the original. Just do a google search to come up with a part number.
May 18, 2009 | Samsung HL-S5087W DLP TV
Samsung DLP HDTV wide screen
Sounds like the colorwheel (used in DLP projection sets with a single DLP panel) is going bad, either the wheel itself or the bearings on the motor driving the wheel are starting to fail. I would recommend getting a professional to service the TV set.
Jan 11, 2008 | Televison & Video
Televison & Video Logo
708 people viewed this question
Top Televison & Video Experts
Electro Med Services...
