Question about Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax
Lexmark x4270 all in one
I have a black line going down the left sdide of my paper when I scan, copy or fax but not when I print. Please help.
  • amcrae Jul 09, 2008
    I cant see the glass, can you direct me to it?
Try cleaning the scanner glass it might have dirt settled on it.Had a similiar problem solved by cleaning it.
Posted on Jul 09, 2008
How can I send and receive a fax from Lexmark x4270.?
You can send faxes via the operator panel, the All-In-One Center, or the fax driver.
Using the Operator Panel:
  1. Make sure your All-In-One is switched on.
  2. Load up to 30 sheets of your original document face down in the ADF (Automatic Document Feeder). Note: When you load small paper sizes, place your document in the center of the tray and adjust the paper guides to the edges of the paper.
  3. On the operator panel, press Fax.
Using the keypad you can:
  • Enter the fax number, and then press Black or Color.
  • Press Speed Dial, and then:
- Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color. - Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
The All-In-One scans your document and sends your fax to the number you entered.
Using the All-In-One Center:
  1. Make sure your All-In-One is attached to a computer.
  3. From your desktop, double-click the Lexmark 4200 Series All-In-One Center icon. The All-In-One Main Page appears.
  4. Under Productivity Tools, click Fax an image or document.
  5. Follow the instructions on your screen to complete the task.
For a more comprehensive guide on how to send and receive faxes using your Lexmark X4270 printer, please refer to the Lexmark X4270 User's Guide.
Aug 17, 2011 | Lexmark X4270 All-In-One InkJet Printer
When I make copies or transmit a fax, it makes a 3/4" black line down the left side. I have cleaned ink cartridges and contacts but does not help.
The line is probably not from the ink cartridges or nozzles (assuming regular printing doesn't streak). Streaks on copies and transmitted faxes are usually due to dirt or problems on the scanner unit. First clean the flat bed of the scanne. If you have an automatic document feeder, clean that.
Clean with a lint free cloth moistened with a little water or glass cleaner. Make sure no foreign objects are in the ADF path or on the glass. For pictures see the Lexmark support site: http://support.lexmark.com/index?page=product&linkSelected=node0&locale=EN&userlocale=EN_US#1. Then enter "streak on copy" - the solution comes up in a pop up.
If the streak is shrinking, then copy a blank white piece of paper to identify where to clean further. Try scanning another page with a small mark on it. (These are particularly helpful for cleaning the ADF.)
If the mark occurs when you print, then check if you have a damaged cartridge or other ink that has spilled inside the printer.
I hope this helps.
Feb 02, 2011 | Lexmark X4270 All-In-One InkJet Printer
There are black vertical lines going down the middle of the page whne i copy or scan and fax documents. What is the problem.
It could be due to some dirt on the scan lens on the printer. Refer to this article on How to Clean the Scan Lens and White Roller on the Lexmark X4250/ X4270/ F4270. I hope this helps.
If you need additional assistance. please contact Lexmark technical support so they can help you. thanks.
Nov 04, 2010 | Lexmark X4270 All-In-One InkJet Printer
Outgoing faxes and copies have black lines down middle of page
This usually happens when the Roll of paper is running out.
If this machine uses sheet paper and not a roll, you may have dirt, a scrap of paper, or something else on the print head.
Check the manual for instruction on cleaning
Jul 21, 2010 | Lexmark X4270 All-In-One InkJet Printer
I have a lexmark all-in-one printer, model # x4270, when I fax someone, when received, the fax is a blank sheet of paper?
try and make a copy with the fax... if it comes out the same way... turn the paper face up if it was face down or vice versa and try again... if it works then fax the same way and see what happens... if all goes well then keep copying and faxing that way... if that works but fax does not work... print an internal report... if that does not print then you have main board problems... if internal prints print then you have a problem with your ccd... thats a big long strip that rests right under the keyboard... thats what does the scanning... if that is bad... then when you fax... or copy it will be blank or black... depending on what is blown on it...
Dec 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
How to send fax from lexmark x4270. lost instructions
  1. Make sure your All-In-One is on.
  2. Load up to 30 sheets of your original document face down in the ADF. ascanld2.jpg
Note: When you load small paper sizes, place your original in the center of the tray and adjust the paper guides to the edges of the paper.
  1. On the control panel, press Fax.
  2. Use the keypad to:
  • Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color.
  • Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
Aug 29, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 fax machine receives faxes but won't feed paper
Try cleaning the rollers in X4270 printer. You may need to clean the scan lens and the white roller.
1. Unplug the power cord and the phone line from the wall.
Open the control panel.
2. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
3. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
4. Reinstall the white roller.
5. Reconnect the power cord and the phone line.
Next, try to make a standalone copy and let us know the results.
Apr 15, 2009 | Lexmark X4270 All-In-One InkJet Printer
Two black vertical lines appear on copy, pdf, and scan results
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax Logo
132 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
