Question about Danby Refrigerators
We have a Danby fridge model #DPR2262W, bought about 4 years ago for our cottage that has no electricity. Yesterday an acrid smell came out of it and later in the evening the carbon monoxide detector went off. We are an old couple and the instructions said to move it to clean out something or other. We can't do that and have nobody here in Provincetown, MA who will come out on the back dunes (we need 4 wheel drive) to fix it. Anyone available on Cape Cod, or any suggestions about what we can do ourselves?
Thanks very much for your offer and your effort. After about another hour I got ahold of someone at the company who suggested some solutions, so I'll try them out. Thanks again.
Mildred
Posted on Jul 03, 2008
Where are fuel pump relays located and how can they be tested?
usually under hood .but telling us the make,model ,year helps
Dec 26, 2015 | Cars & Trucks
Danby propane fridge model # dpr2262w-6. the freezer still works great but fridge portion does not . the fridge has a bad smell. the fridge is at a cabin and no service
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Danby DPR2262 Top Freezer Refrigerator
I HAVE A DANBY GAS REFRIGERATOR WHEN IT WAS NEW ,7 YEARS AGO I NEVER HAD TO CLEAN AND BRUSH THE VENT PIPE IN THE BACK OF THE UNIT. NOW EVERY 3 MONTHS IT SEEMS I NEED TO BRUSH THE PIPES OTHERWISE I GET A...
the smell you get is bacteria from the condensate(it is similar to the legionaire bug)cover all electrics and spray with a strong clorine bleach solution.and because it gets a little greasy(check your windows)all the dust and s..t sticks to it....the clorine will clean it off.also when degreased use a vacuum cleaner to remove all dust.
some people only clean behind there fridges once every ----- years.
treat the back of a fridge the same as your bathroom for cleanliness.
Aug 21, 2010 | Danby (DAR604BLS) Refrigerator
Danby DPR2262W fridge won't cool, freezer works great
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 05, 2010 | Danby DPR2262 Top Freezer Refrigerator
Hole burning through floor of Freezer
Your refrigerator is likely a frost free model. There is a heating element that runs around the freezer compartment. It is probably the heating element that is causing the original damage to progress.
Most fridges have a way to turn off the frost free part, usually via the timer or or easy as pulling the fuse for the circuit. Pull the fridge out, climb behind it, unplug fridge, and remove access cover, if equipped. Look for a wiring diagram. It will tell you where you need to disable the frost free at.
If you can't disable the frost free, then replace fridge now. the acrid smoke you smell is toxic, and is detrimental to food, as well as to human life. Stop using the fridge, or disable frost free.
Nov 02, 2009 | Magic Chef CTB1922 Top Freezer...
Screen got wide; nasty acrid smell like chlorine or ozone started
One or more electronic components was burned or deteriorated inside the tv.
Replace the TV.
May 24, 2009 | Sylvania 6427TE 27" TV
A funny smell and i think it might be the temperature
Adjust the knob to 3 or 4 which would be the midway temperature.
0 would probably be off or close to it. The 7 would be coldest and freeze water.
If this is manual defrost you need to turn it off and defrost it. The frost will keep it from getting cold enough. The buildup is normal from humid warm air when opening the door. You might get a standalone fridge / freezer thermometer (about $5) to tell you what temperature is. The smell may be food spoiling from warm temperature.
Mar 20, 2009 | Danby DDW1805W Designer Series...
Danby compact 482 fridge is freezing everything. thermostat switch seems to check out.
Hello tbrown7777
Welcome.
You said, Your Danby compact 482 fridge is freezing everything. thermostat switch seems to check out.
Just 482 is incomplete!!!!!!!!!
Can you send me the complete model number off the sticker in the fridge or on the rear of the fridge?
and the year of it! waiting your response!
Huuum
Oct 20, 2008 | Danby Refrigerators
Funny smell from RS2630SH
Dear friend,
ngfam at you service! happy to assist!
Whirlpool sells odor stoppers for your fridge!
And keep a open box of baking soda on the door always!
HERE IS THE WHIRLPOOL SITE BELOW
http://www.whirlpool.com/catalog/
accessory_category.jsp?parentCategoryId=
323&categoryId=370
How old is the appliance ?
If it's 10 years old or more it's not worth sinking good money into bad !Todays appliances are so much more efficient that you save money on you electric bill!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
238 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
