Question about RCA H100 MP3 Player
The phono jack on my son's H100 is loose
The phono jack is somehow loose inside. We only get sound when inserting about 60% of the way and leaning the plug to one side. I want to know how to open the case so I can get inside and fix it.
You mostly likly could, you dont have the tools to do it, just go to where you bought it and see if they can help or just buy a new one!
Posted on Aug 04, 2008
Studiomaster manual
On the rear panel there are two jack socket marked: Left and Right Insert.
These are connected to the graphic equalizer using two insert cables, one for each channel ( L & R). The cables have a stereo 6.35mm jack plug which plugs into the mixer, the cable splits into two mono jack plugs marked tip (or send) and ring (or return). The send (tip) connects to the input of the graphic equalizer and the return (ring) connects to the output of the graphic equalizer. How it works: The stereo jack interrupts the signal in the mixer and sends it to the equalizer, the equalizer processes the signal then sends it back to the mixer. Typical cable is shown below. If the equalizer has a different type of socket, phono for example you will need jack to phono adapters or insert cables with suitable plugs. Hope this helps.
Apr 05, 2014 | Audio Players & Recorders
Just wondering if there is any way to hook an iPod (actually my iPhone 3GS) to my stereo (SA-AK57) somehow to play my songs??
only in stereo, there is not digital interface for this sound system, you need a 3.5mm jack to RCA lead (Head phone connector on end and a red and white phono connectors on the other) these connect to the Aux 1 or Aux 2 inputs on the rear of your stereo.
Jun 20, 2010 | Panasonic Audio Players & Recorders
I hooked up my new stanton t-60 turntable to an older sony amp that does not have a phono jack. i used a behringer pp400 preamp to connect the turntable to the amp. the sound is coming through with heavy...
Are you using the phono input on the Sony? If so, you're getting too much gain, you've already got a phono pre amp in the Behringer. Try using the tape or C.D. input. That should solve it.
Jan 16, 2010 | Stanton STR8-60 Turntable
Can i listen to my ipod threw the theater sound system
your home theater has a AUX phono plug in the back
you need to buy or make a cable that looks like this
to buy
3.5mm headphone jack>>>>> phonojack
if that cable has only one phono jack on the other side then you also need this
one phonojack>>>>>two phono jacks
this is needed because if you kept it as one jack then only one side will play music
if you make it then
3.5mm headphone jack>>>>>> two phono jacks
Jan 11, 2010 | Panasonic SC-HT520 System
I have a Sony MDS-JE520, NO SOUND!! but the rest seems to work
stick it up your *** 3 times and it will do the trick :D
Mar 20, 2009 | Sony MDS-JE520 Mini Disc Player
How to hook up a sound system
Go to Radio Shack. Find the phono adapter and cable section of the store. The adapter you want has a one eighth inch male plug on one end, and a set of female phono plugs on the other. Insert the male end of the adapter into the stereo headphone jack on the side of your television. Run a set of phono cables from the adapter to your receiver. Turn the volume of your television up to the maximum (100.) You should be able to switch between the different surround settings in your menu.
Jan 06, 2009 | Polaroid FLM-4234BH 42 in. LCD HDTV
Help! Surround Sound problems!
Since you have a surround sound system, you probably should just bypass the TV's audio.
Connect the red/white plugs from your digital cable box to one of the inputs on your surround sound system but not the Phono input unless the Phono input lists something aside from Phono, like Aux/Phono or CD/Phono.
Connect the S-Video or composite (yellow) video plug from your digital cable box directly to the S-Video or composite (yellow) video jack on your TV.
If your digital cable box does not have a S-Video (4 pins and flat rectangular hole) or Composite (yellow RCA jack) jack and only has the screw/push-on type cable with the pin in it, then leave the remaining connections as-is.
Now switch your surround sound system to the input you connected the red and white plugs to and turn on your TV. You should see picture from the TV, but hear audio from the surround sound system.
Apr 06, 2008 | Emerson EWF2004 20" TV
Sony bravia to my P/C
You need to wire up the audio from the computer.
The 15 pin cable is only the video, next to the input on the tv should be a red and white phono connector which should say audio or line in, get a cable that has a headphone type jack on one end and 2 phono red and white plugs, connect the headphone jack into the back of the pc, should be the green audio out where you would usually connect pc speakers, then the phono plugs into the back of the tv and insert them into the phono ports on the back of the tv that say line or audio in. Turn the TV to PC and thats it.
hope this helps
Dec 02, 2007 | Televison & Video
Rane Mixer ttm 54
in sound system you have different sound level start with phono level up to line level up to speaker level.-you will switch to phono when you connect phonograph and you will switch to line when you connect another audio source like dvd and video sound.
Sep 01, 2007 | Rane PE 17 Home Equalizer
RCA H100 MP3 Player Logo
35 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
