Question about LG RE-44SZ21RD 44" Analog Television
WARNING LIGHT ON FRONT OF TV
THERE IS A ORANGE WARNING LIGHT COME ON NEXT TO GREEN POWER LIGHT ON THE FRONT OF TV. THE PICTURE LOOKS LIKE A LIT UP LIGHT BULB. WHAT DOES THIS LIGHT MEAN.
  • 21 Answers
Your Tv requires the lamp hours to be re-set. You will need to acess the Service mode settings via a service remote from your authorised LG service agent.
Posted on Nov 10, 2008
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
I have an lg projection tv model #RU-48SZ40. I needed to change the lamp, when I was done and turned the tv back on...the orange warning light was still lit. I then tried unplugging the tv, pulled the lamp...
What you need is to have the lamp timer reset. To do so, perform the following;
You will need two hands.
With the remote, press and hold down the "mute" button.
Simultaneously press and hold down the "enter" button on the front of the TV.
After about 5 seconds, a box will appear that shows the total number of hours on the lamp. To reset these hours, press the right arrow button on the remote. After doing so, another box will appear with a confirmation question and an icon for which button on the remote to press to reset the lamp hours.
Dec 15, 2010 | LG Televison & Video
The little orange light next to the regular green light that appears when the tv is on is lit up....I suppose it has to do with bulb however the tv appears to work just fine...what does this light mean
Yes,the tv projection bulb life is ending.Sometime the LED light indication "LAMP"light up or blinkig,tv still work,because it just giving u a little advance warning that all.The "LAMP" LED indicaton light,light up right?
Sep 14, 2010 | Zenith Z52SZ80 TV
Takes to long for unit to come on, when pressing power on remote, green light comes on, but it takes over an hour for the picture to come on.
could be a lamp problem, turn the set off, watch the front led light next to LAMP, count how many flashes in sequence, eg. 2 flashes indicate lamp problem, 3 flashes internal overheat problem. if a orange light flashes next to POWER indicator you have a power malfunction.
Aug 22, 2010 | Panasonic PT-61LCZ70 Television
50" vizio hdtv will not turn on and light in front not on
If TV is completely dead, no green/orange light, no any clicking sounds after you unplug it from the wall outlet and plug it back in - it is a problem with Power Board. Best case scenario - It's just a fuse that needed to be replaced. You have to remove back cover and locate fuses (1-4) on the board that power cord is attached to. You have to use multimeter to check it. If fuses are OK - next step is to replace whole power board. But before you do anything - make sure you got power out of the wall outlet and/or your power strip is in working condition.
Mar 10, 2010 | Vizio Televison & Video
RCA L42WD22YX5 TV green light but no sound/picture
Recommend opening it up and looking at the power board and see if there are any visible Bulged or leaking capacitors.
Bad caps are a major source of computer and LCD no post problems.
If you find em, then just find replacements with the same uF and voltage and solder them out/in.
Dec 28, 2009 | RCA L42WD22 42 in. LCD Television
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
LG RE-44SZ21RD 44" Analog Television Logo
301 people viewed this question
Computer Repairing
Computer Repairing
