Question about Fujitsu fi-4120C Path-Through Scanner
How to Default Duplex Scanning
Is there a way to default duplex scanning (in the scanner settings) rather than having to go through the wizard and selecting duplex scanning each time I use the scanner?
  1. Image Scan Can not be Found.
  2. please check and Cable connection
  3. and the scanner is not used by other application.(Code:DS42019)
THIS THREE ERROR WILL SHOW AT MY SCANNER.
AFTER PUT GHOST IT WIL SLOVE.OTHERWISE WIL NOT SLOVE.
COULD U PLS GIVE SOLUCATION
Posted on Jul 16, 2008
Will Only Scan Color and single sided
Once I had a similar problem with CapturePerfect 2.0. No amount of setting will change the scan output. I hit the default option and then changed to the setting I wanted. It worked. May be there is a bug in the Scanning software.
S. Mohan, India
Jan 09, 2014 | Canon DR-3080CII Path-Through Flatbed...
Cancel double sided copying
Slide the DUPLEX switch to the one sided mode on the ADF.
Also you should be able to set the single and dula sided mode from your scanning application in the setup tab.
Oct 15, 2009 | HP Scanjet 8250 Flatbed Scanner
Canon Dr2050C Duplex scanning reverse page all black
Check your brightness setting for backside. Ideally keep it automatic, else you can manually choose the right brightness.
S. Mohan
Sep 18, 2009 | Canon DR-2050C Path-Through Scanner
Fi-5750C Fujitsu scanner can't change grayscale default setting
Photoshop is not an "advanced" scanning program. To get some "production" and value out of this expensive scanner you need a professional scanning program which also may control the settings of the scanner. Use PixEdit which utilizes the built-in jpeg compression in the scanner. Did a test scanning 10 pages A4 duplex fullcolor. Adobe Acrobat Pro used 4 minutes. PixEdit used 20 seconds. Guess Photoshop (in your version) would also scan uncompressed and not use this good scanner optimal.
Jun 26, 2009 | Fujitsu fi-5750C Flatbed Scanner
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
No duplex scanning
Try going to the hp solution center
Then settings, scan settings, scan preferences (third from top), under the automatic tab, bottom of list is “Scan both sides of the original when using duplex feeder”
I’m using version 70.0.128.000 of the HP Solution Center if that helps.
I told my brother once to ask HP support about a problem for his laptop, and they proceeded to instruct him how to make the problem worse and royally screw up stuff that was completely unrelated to his problem.
Jan 11, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Copying duplex documents
Go here for an online document to help you solve this scanning of a duplex document issue.
or type in
http://www.fixya.com/support/p258233-xerox_documate_510_flatbed_scanner/manual-6075
May 01, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Duplex Scanning
I havent used WYNN wizard. I use Capture perfect ver 2.0 it is available free of cost. Try with it. If it is okay, then may be some setting is missing. If it remains same, then there be some hardware issue in the scanner.
S. Mohan
Apr 16, 2008 | Canon DR-7580
Can Scan A5 size duplex
The software on my X4500 unit allows duplex scanning of A5 paper. Updating the firmware and software is fairly easy if you need to.
Nov 20, 2007 | Lexmark X4500 MFP Flatbed Scanner
Duplex Scanning
If the line appears in the same location, it is definitely dust sticking to the glass. How thick is it? If it is thick, it may be because of an LED failed to glow, but this is etremely rare. If you are getting line in Duplex mode and not in simplex mode, it is on the second scanning module! Try cleaning with Isopropyl Alcohol (IPA). If you have been scanning old documents which tend to break like biscuit or get powdery, a speck can enter into the scanning area and create trouble.
S. Mohan
Oct 26, 2007 | Canon DR-2050C Path-Through Scanner
Fujitsu fi-4120C Path-Through Scanner Logo
909 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
