Question about Acer Computers & Internet
When trying to set up my wi-fi for tiscali the key number I have been given is 11 numbers and it needs to be 5 or 13. Acer support are not answering there phone they are just hanging up. Can someone please help? My wi-fi has worked at another location with another server so I don't think there is a problem with that side of it. Have gone through with Tiscali technical department and they can see my computer the router is picking it up . Help!
    Guru:
  • 1,342 Answers
Try changing the input method from HEX to ASCII
Posted on Jul 02, 2008
Can't get wi-fi connection
There are a number of reasons why you may not get a wi-fi connection:
  1. No connection available
  2. Poor signal strength
  3. Wi-fi on device not turned on
  4. Faulty wi-fi driver in device
  5. Using wrong wi-fi security password
  6. Router has your MAC address blocked
  7. Faulty wi-fi module in device
If you can give specifics on what you have tried and what the results are we may be able to narrow down the possibilities.
Oct 25, 2015 | Computers & Internet
How do I find my SSID number on Acer Iconia One 7
The SSID number is the identity of the router you are trying to connect to, not your computer.
Turn on the Wi-Fi under settings and look at the list of SSID's there.
Feb 15, 2015 | Acer Iconia One 7 B1-730HD-11S6 7-Inch HD...
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Acer d257 wifi is not working after reinstall
try latest driver . check also if airplane mode is on !
http://www.acer.com.au/ac/en/AU/content/drivers
find wi fi driver for your d257 use serial number or model number. You may need to open cover on bottom of laptop to see which rf board is being used in your laptop as I found a aod257 but it had three possible wi fi drivers . but aod257 may not be your model number.
select the correct operating system in the web page
Oct 08, 2014 | Computers & Internet
How do i set up netgear to recognize kindle fire
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.0.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and password for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select saveand apply.10. you can now restart your kindle then try to search for wireless networks again and when you got your netgear wi-fi name press connect.11. you will be asked to enter your WEP key or your Pre-Shared Key.12. enter your password that you use in the instruction number 8, then press OK, then you are good to go.
Dec 25, 2011 | NetGear Computers & Internet
My Kindle is not picking up the wi fi signal what code do I need to put into it??
Try this:
  • Press the Home button, then press the Menu button.
  • Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  • Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks.
  • Use the 5-way controller to navigate down to "Enter other Wi-Fi network" and press to select.
  • Enter the name of the Wi-Fi network that you want to add.
  • Enter the password (if required). Press the Symbol key to enter numbers or characters not present on the Kindle keyboard. You can continue to use the keyboard while the Symbol menu is displayed.
  • Choose "submit." Kindle connects to the new Wi-Fi network.
  • If this doesn't work feel free to reply and I will try find another method. However, if it does please rate me. Thank you.
    PCHELPSTER007 from youtube
    Jul 06, 2011 | Computers & Internet
    Does acer aspire 5742 have wi-fi
    Actually, Wi-Fi is another term for Wireless Network. Well, the answer to you question is Yes, it is a wi-fi ready machine. You don't need any additional hardware to access a Wi-Fi network, in other words, it is a wi-fi certified machine. Hope this helps.
    Good Luck.
    Thanks for using FixYa.
    Apr 11, 2011 | Acer Aspire 5742Z-4200 Notebook
    Just need to know what button to use to turn on wi-fi for an Acer Ferrari 1000 laptop. Thank you
    There is a button in the middle-front of your laptop that will turn on wifi. It has an image of two ovals and a stick on it.
    For more information, I have provided a link to the manual for your model below. Information about the wifi switch is located on page seven, specifically number seven on that page.
    http://tim.id.au/laptops/acer/ferrari%201000.pdf
    Hope this helps.
    Mar 15, 2011 | Acer Ferrari 1000-5123 Laptop
    How to turn off wi-fi
    Hi
    Thank you for your query
    If you look at the top of your netbook, you will notice there are a few buttons, one of them will have a picture of a satellite on there. That button is your wi-fi button and will allow you to switch wi-fi on and off
    I hope this helps
    Mar 01, 2010 | Acer Computer AOA150 Notebook
    Trying to enable the wi-fi on my acer 3693WLMi
    install an application called 'Launch Manager' That will help. You didn't say what model? Acer Extensa 2000/2500 Series --- Far right launch button above the keyboard
    Acer Travelmate C Series ---Far left hot key and then choose WLAN from menu that appears
    Acer Aspire 1000 Series --Launch Keys above the keyboard
    Acer Aspire 1640Z ---- Launch Keys above the keyboard
    Acer Aspire 1690 ---- Launch Keys above the keyboard
    Acer Aspire 2000 Series ---- Button on the front of the laptop
    Acer Aspire 2012 ---- Launch Keys above the keyboard
    Acer Ferrari 3000 ---- Button on the front of the laptop
    Acer Ferrari 3020 ---- Button on the front of the laptop
    Acer Ferrari 3400 ---- Button on the front of the laptop
    Acer Ferrari 4000 ---- Button on the front of the laptop
    If you don;t have the drivers go to the Acer site and download them, and install.
    Feb 27, 2010 | Computers & Internet
    Computers & Internet Logo
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
