Question about Bosch Axxis WFL 2060 Front Load Washer
Replacing the boot gasket
I just got a replacement boot gasket for my washer.  Can you explain what the process is to install the new boot gasket?  I tried removing the door but the top of the door has two screws holding it and on the right inside of the door there is a blue wire that looks like it is connected to the machine
Please help.
Thank you
  • 483 Answers
Try following this link :
http://www.applianceaid.com/boot.html
Many got help, didn't paste the entire thing here as didn't wanted to spam the site.
Thanks
Posted on Mar 27, 2009
Need to remove old Door Boot/Gasket & replace new one. How do I proceed?
Hi
Please check this service manual for your LG WM2487 washer if you want to do this yourself. Hope this helps...please post back for further assistance.
Daniel
Jul 21, 2011 | LG WM2487H Front Load Washer
How do i remove door gasket on my wfmc3200 washer
Be careful to allow the new door gasket to relax for at least a day before doing the installation. Take it out of the box and lay it out in a circle to help get any kinks out of it.
Also, when installing the new gasket, go slowly when stretching it over the edges of the washer drum and the door edge, being extra careful to make sure you align the gasket properly on the washer. You might want to take a digital picture of the existing gasket before you remove it, so you can refer to it when reinstalling the new gasket.
Some models have a port for the water inlet on the gasket, if your's does, install the gasket over the inlet first, then move onto the rest of it. If your's doesn't have a inlet port opening in the gasket, just be sure you have the gasket orientation correct.
Replacing a door gasket/boot is one of the things that most homeowners can do themselves and save yourself having to pay for a technician.
Here's a exploded line drawing of your washer, so you can see the parts and order of installation before you dive into taking things apart.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFMC3200UC-01&productCategoryId=0153200&brandId=1794&modelName=WASHER&diagramPageId=00002&componentDescription=DOOR%20ASSEMBLY&documentId=P0507026&backToLink=Return%20to%20Sub%20Components%20list
COURTESY:VTTOOLMAN----EXPERT OF FIXYA
Dec 29, 2009 | Bosch WFMC 3200 Front Load Washer
Door boot seal on a front load washer how to change
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
Nov 11, 2009 | GE WSXH208A Front Load Washer
Hello; I have a GE Front Load washer and seem
You can't repair the seal, but you can replace it with a new one for under $130 if you do the replacement yourself. You can order it online or from a local appliance shop, as prices vary slightly from place to place. I suggest www.searpartsdirect.com as they usually have the part in stock and you can get it shipped to you anywhere in the US without having to run all around trying to find one locally, etc.
The tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washing machine.
I'd suggest you call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct substitution bellows gasket.
It's a relatively easy repair, all you need to do is remove the spring retaining wire around the outer edge of the bellows gasket, just peel it back at the edge to see it. Now locate the locking loop by going around the rim. Once you find the locking loop, you can remove it using a couple pairs of small needle nose pliers as they make it easier to get off.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer wash tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
Here's a line drawing that shows the exploded view of the tub section, with the gasket (item #306). Just take your time removing the old gasket so you remember what you're doing and when installing the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WBVH6240F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090504&backToLink=Return%20to%20subcomponent%20list
Here's another link to one of my other solutions for installing a bellows gasket on a GE front loading washer that you can also review for more installation tips, etc.
http://www.fixya.com/support/t2730376-need_help_in_installing_door_bellow_ge
Hope you find this Very Helpful and best regards!
Sep 20, 2009 | GE WBVH6240F Front Load Washer
Im needing to know how to install the replacement door boot-bellow seal on my front load washing machine. i purchased the seal that i was told is a universal seal due to the original seal part no longer...
Candie, The tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer washer tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WBVH6240F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090504&backToLink=Return%20to%20Sub%20Components%20list
Sep 17, 2009 | GE WBVH6240F Front Load Washer
Broken door gasket how to replace on GE front
You'll need to determine which bellows gasket your washer needs before you undertake the repair. Go to the following link and enter in your washer model number to get the line drawing and parts breakdown.
http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
Click on the "find a part" and enter in your model number
Typically, the tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
You can also call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct substitution bellows gasket.
Sep 15, 2009 | GE Washing Machines
Want to replace door boot as well on Bosch WFMC3200
Sep 03, 2009 | Bosch WFMC 3200 Front Load Washer
Kenmore elite duet 410 metal wire for gasket came off
is it a metal wire connected at bottom with a 2-3inch spring???? is so it secures the "bellow to the front lip of the machine. youlll need to stretch it over the front "bellow lip after installing the "bellow"
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Front door gasket whirlpool duet washer
before replacing run a empty load with alot of bleach in it and then clean boot with a mold cleaner like kitchen cleaner w/bleach replacing the boot isnt something you want to do unless you have to do it (not easy) and the cost of the boot if you need any more help let me know and i will guide you thru the process of the boot
bill
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
179 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
