Question about Dryers
Maytag performa dryer
I have a friend that has a Performa dryer, she states that she had the on/off/ selector switch replaced but the dryer will not start. When you depress the start switch, the buzzer sounds. PLEASE HELP!!!!!
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Posted on Jul 04, 2008
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
My Maytag Performa PYE2300AYW keeps running and won't get to hot on low but on Regular it gets too hot
your cycling sensor thermostat is getting defective it will have 1 side a red wire coming off the heat selector switch and the opposite side will be a yellow wire from the safety thermostat connection
Nov 15, 2009 | Maytag PYE2300AY Electric Dryer
I have a 10 year old Maytag Performa. It started
Hello, try checking the door switch, with no light in the drum it points to the door switch being bad. To test this unplug the machine, bypass the door switch with a wirenut..Don't forget to replace the switch if bad, the door switch is there for a reason. Good Luck!!! Please feel free to comment again if you have any other questions or concerns. Mike
Jul 23, 2009 | Maytag Dryers
Maytag Performa Dryer won't start.
I would suggest checking and probly replacing especially if you cant hear the timer motor.
Mar 28, 2009 | Zanussi TD4112W Electric Dryer
Dryer won't come on
motor relay on control board, thermal fuse or breakers are tripped, check breakers 1st
Dec 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag performa gas dryer no longer produces heat.
needs a new timer switch sometimes cheaper to buy another dryer (used)
Dec 02, 2008 | Maytag Performa PAV2200
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Dryers Logo
597 people viewed this question
Top Dryers Experts
