Question about Microsoft Windows XP Professional
Microsoft Office Outlook
Cannot start Microsoft Office Outlook. Cannot open the Outlook window. The set of folders cannot be opened. Errors have been detected in the file C:Documents and SettingsOwner.YOUR-A595C864D0Local SettingsApplication DataMicrosoftOutlookOutlook.pst. Quit Outlook and all mail enabled applications, and then use the Inbox repair tool (scanpst.exe) to diagnose and repair errorsin the file. For more information about the inbox repair tool see HELP.
I have run the scanpst.exe and nothing works, I also searched for the Inbox Repair Tool...My version is 2007 Prior version was 2003 and we overwrote it thinking this would coorect the problem...I have all information for the 2007 purchase...Please help...I have all my tracking for my email....that needs to be restoreed
  • Anonymous Jan 22, 2009
    the solution did nothing, are there typos in the Bety's description by any chance?
    example did not help at all: Start: Run. . and enter something like "C:\Program Files\Microsoft Office\OFFICE11\OUTLOOK.EXE" /cleanprofile .
    Problem Solver:
  • 14 Answers
Run Outlook from a command line with the /cleanprofile switch appended to the command.
To find the correct command line, right click on a shortcut for Outlook and go to Properties. Copy the information in the Target field and Paste it to the command line. If there is already a command option, remove it and add /cleanprofile after the closing quotation mark. (Add a space before /cleanprofile)
For example, go to Start: Run. . and enter something like "C:\Program Files\Microsoft Office\OFFICE11\OUTLOOK.EXE" /cleanprofile .
Then add a new profile. Be sure to check the check box for "Set as default profile". Note: You cannot see this option unless you click on the "Options >>" button.
This should fix the problem.
Posted on Jul 02, 2008
I keep getting an error message that says, "Microsoft Outlook. Cannot open the Outlook Window. The set of folders cannot be opened. Errors have been detected in the file C:\Users\my name\AppData\Loc
To resolve this problem, use the following steps. On the Start menu click Run. In the Run dialog box, type the following command:
Outlook.exe /resetnavpane
Note:
There is a space between "Outlook.exe" and "/resetnavpane" Click OK. Note If you are using Windows Vista or Windows 7, you may not see Run on the Start menu. In this situation, use the following steps to locate the Run option. On the Start menu click All Programs. Click Accessories. Click Run.
Apr 15, 2013 | Dell Computers & Internet
When opening Outlook I receive the following message, this occurred after I tried to email a photo out of a photo program: "A data file did not close properly the last time it was used and is being...
1. In Outlook 2007, click the Tools menu and select Options.
2. In the Options dialog box, click the Mail Setup tab and then click the Data Files button.
3. In the Account settings window, you will see all of your personal Outlook data files listed. Here, you want to note the full path to each data file. On my system, my Outlook personal and archive folders are stored in the C:\Documents and Settings\Your Username\Local Settings\Application Data\Microsoft\Outlook folder.
4. Once you have this information, close the Account Settings dialog box and then close the Outlook Options window.
Now that you have the location of your Outlook data files, you need to check and repair them using the Microsoft Office Outlook 2007 Inbox Repair Tool-SCANPST.exe. By default, you should see SCANPST.exe in the Microsoft Office installation folder's "Office 12" subfolder. On my system, SCANPST.exe is located in C:\Program Files\Microsoft Office\Office 12. For additional information on SCANPST.exe, take a look at the Microsoft Knowledge Base article, "How to use the Inbox Repair Tools to recover e-mail messages in Outlook 2002 and Outlook 2003."
To check and repair your Outlook data files, follow these steps:
1. First, close Outlook 2007.
2. Use Windows Explorer to browse to SCANPST.exe, then double-click it.
3. When the Outlook 2007 Inbox Repair Tool opens, click Browse and navigate to the Outlook data file location that you found earlier. Note that you will need to check each file listed. On my system, I start with the file archive.pst. To check that file, you would select it in the "Select File to Scan" dialog box and then click Open.
4. Now click Start to begin the repair process.
Mar 05, 2011 | Sony Microsoft Office Standard 2007
Outlook program has refused to open and ask that I check internet for solution
Try to open Outlook in safe mode. Follow thses steps to do it.
1.Click on start button (for Vista it will be Windows button ) and click on Run.
2.Type outlook.exe /safe and press enter.
3.If outlook is not starting then we have to do a detect and repair. Follow these steps to do that.
Detect and repair.
1.Click on Start button (for Vista it will be Windows button ) and click on Run.
3.Go to Help tab in Outlook and select office diagnostics, click on continue and click on Run Diagnostics.
Method 2:
Try to open Outlook without addins.
1.Click on start button and click on Run.
2.Type outlook.exe /a and press enter.
If he can open Outlook in this way, then the third party addins are causing the issue. This can be resolved by
removing the third party addins. Follow these steps to remove third party addins.
1.Open Outlok and click On the Tools menu, click Trust Center, and then click Add-ins.(for Office 2007).
2.In the Add-ins box, identify the add-in that you want to disable and note the Add-in type located in the Type
column.
3.Select the Add-in type in the Manage box and then click Go.
4.clear the check box for the Add-in that you want to disable and then click OK.
  • Method3:
    Press Cntrl+Alt+Delete to open task manager and click on processes. click on outlook.exe and click on End process.
    If there is multiple outlook.exe running end all of them. Try to open outlook after ending all outlook.exe processes.
  • 4
    Method4:
    Take a back up of pst files and reinstall Outlook . follow these steps to take a backup of pst files.
    1.Close any messaging programs such as Outlook, Microsoft Exchange, or Microsoft Windows Messaging.
    2.Click on start button and go to setting and open control panel.
    3.Double-click the Mail icon.
    4.Click Show Profiles.
    5.Click the appropriate profile, and then click Properties.
    6.Click Data Files.
    7.Under Name, click the Personal Folders Service that you want to back up. By default, this service is called Personal 8.Folders. However,
    it may be named something else
    9.Click Settings, and then note the path and file name that appears.
    10.Close all the Properties windows.
    11.Open the file through the path and copy it to a new folder as backup.
  • Oct 05, 2010 | Computers & Internet
    I have Microsoft Office 2007 for small business on a relatively new Dell laptop that I purchased around 6-months ago. It can pre-loaded from Dell. Everything worked on Office just fine until about a week...
    The only thing i can sudgest is to do a repair installation, go to uninstall in control panel, click on uninstall/change office, and click on the option to repair
    Sep 10, 2010 | Microsoft Office Small Business 2007 OEM...
    Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
    This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
    To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
    1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
    2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
    3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
    To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
    Or If you are receiving and Err like
    Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
    To resolve this issue, follow these steps:
    1. Locate Outlook.exe.
      Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
      • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
      • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
      • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
      • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
      • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
    2. Right-click Outlook.exe, and then click Properties.
    3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
    4. Click OK.
    5. Try to start Outlook. If you receive error message again, use Method 2.
    Regard's
    Pcs365.8
    Jun 16, 2010 | Microsoft Windows XP Home Edition
    Outlook 2007 will not open .Program has run well for 2 years. Now its impossible to open/start the program.Always get this message: "Cannot start with Microsoft Office Outlook.Cannot openthe Outlook...
    Inbox repair tool(scanpst) is the best tool that can be used when you are finding any difficulties to connect your inbox folders or pst files or it is reporting that your Inbox folders or Outlook PST file may be damaged in Microsoft Office Outlook 2000 (or higher).Scanpst is a tiny tool installed by default when installing Microsoft Office 2000 or higher. PST files or Personal Folder Files are used by Microsoft Outlook for storing Outlook data, including mailbox files, email folders, contacts or any other personal data related to Microsoft Outlook. see the step by step instruction here
    http://soluzia.net/How-to-repair-Outlook-folders-using-the-Inbox-Repair-Tool.php
    Mar 16, 2010 | Microsoft Office Outlook 2007 for PC
    Cannot open Microsoft Outlook
    I think you are trying to run outlook in Compatibility mode. Which is why Outlook window isn't opening.
    You can try following solutions.
    1) Search Outlook in start menu search box then right click on outlook and select Open File Location. You can see the following image for this.
    2) Now select Outlook and right click on that & select properties.
    You can see the following images for that. cannot-open-microsoft-outlook-w3i35ygaym0a2mtgexp5w2fh-2-2.png
    3) Now click on Compatibility tab and Uncheck the checkbox "run this program in compatibility mode" and at last click on Apply then OK. You can see the following image for this.
    Now, I hope Outlook will work properly.
    Jan 22, 2010 | Microsoft Office Outlook 2007: Windows
    Microsoft Windows XP Professional Logo
    417 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
