Canon PIXMA MX310 All-In-One Printer Logo
Posted on Jul 02, 2008
Can't Scan with MX310 hooked up to Time Capsule
I have my MX 310 Hooked up to my Apple Time Capsule and I cannot use the Scan function with the Navigator Software. It says that Scanner cannot connect with the machine.
I can print from my Mac with this setup, is there a problem with scanning? How can I Select Source?
Please help!
Rob
  • 1 more comment
  • Anonymous Nov 21, 2008
    Same Problem, MX310 is connected to a time capsule and cannot scan. All other functions are ok.
  • gregfree Nov 28, 2008
    Any updates on this is a solution here or coming?
  • Anonymous Dec 02, 2008
    i need help with scan
A
Anonymous
Guest is totally 100% correct. you cant scan wirelessly, cause it wont know where to send your copies to. you have to HARDWIRE to scan.
A
Anonymous
If you mean you connected it to the airport, that only supporting printing, not scanning. Have to plug it into the computer.
The canon 310 MX is not able to accept new ink cartridges error 6000
if you purchased a canon 310 mx and if it is new..contact the supplier about it.So that they can instruct you how to fix it..Good day
I am trying to hook up a Canon MX 310 to my MAC and tried to download the driver and end up with an error message. Failed many times and just can't figure it out...can you help?
Depending on which Mac OS you are running you shouldn't need to download a driver - most Canon printers are included in the Apple software from X10.5
I have a Canon MX-310 Printer. Excellent. But, how can I print pages double-sided?
Hi!
Unfortunately it does not have a duplex function and you will have to manually duplex the pages meaning,Print and turn the page around and print on the other side!
Sorry!
1helpful
Does canon pixma mx 310 work faxing page up or page down?
When using the ADF load the document with the side you want to copy, fax or scan facing UP in the ADF.
When using the platen glass load the document with the side to be copied, faxed or scanned facing DOWN on the platen glass.
Trust this helpful.
Please vote.
Canon MX 310 Scan Problem
re-install the printer. or google the code
2answers
MX 310 Not seen in Mac printer list, so cannot install
Had a new hard drive installed and need to re-install Canon Pixma Mx 310 all in one back in my Mac
1helpful
Reset mx 310
This really worked with my MX 310:  http://www.fixya.com/support/t378057-reset_ink_levels_canon_mx310
old marine
old marine
ZJ Limited
ZJ Limited
