Question about Samsung ML-2550 Laser Printer
Samsung ML-2550 manual paper source not working
The manual paper feed has stopped working, and the printer will only take paper from the main paper tray. I cannot remeber when i last used the manual feed, but it could have been before I changed to a Vista Ultimate operating system. Samsung support shows no downloads available for this printer. Any suggestions you have as to how this problem can be resolved will be most welcome.
Black trips on left side
Posted on Sep 09, 2008
My Samsung laser printer ML-2510 keep wont stop running (two lights are blinking same time) until I manually turn off the switch.
After removing the pickup rubber (and not removing the rubber band from it's plastic drum) I cut a thick piece of card stock paper the width of the rubber band and slid it under the rubber. I thought it would make it contact the paper with more force and it worked great.
Dec 04, 2011 | Samsung ML-2510 Laser Printer
Samsung ml-2550 paper jam1 problem
Carefully check for any paper stuck in the system.
Does the error go away on reboot? or is it constant?
Does the error occur every time you print or just sometimes?
May 06, 2011 | Samsung ML-2550 Laser Printer
Samsung ml 1210 paper feed does not work
Ew. On a printer like this, if the paper feed doesn't draw paper in via the rubber rollers, then the printer is likely not good.
I checked the manual, and its copyright is 2001. Over time the rollers dry out and will not draw paper in as originally required when new.
I wouldn't invest too much into this printer, as, the parts are probably not available at this point in time for it.
Jan 19, 2011 | Samsung ML 1210 Laser Printer
Wheres the manual paper feed on a samsung ml-3051n
The Upper Tray (Tray-1) is the Manual Paper Feed Tray.
CreativeTECH
Jan 05, 2011 | Samsung ML-3051N Laser Printer
Defeito outbin full da empressora samsung 2550
The plastic paper guide where your paper exits the printer is stuck in the up position triggering the sensor. Push the plastic guide down and it should solve the problem
Nov 11, 2009 | Samsung ML-2550 Laser Printer
Internal error mdlcrum 0094 in samsung printer ml-2550
I HAVE A PRINTER SAMSUNG ML 2550 ERROR CODE MDLCRUM 0094
Mar 27, 2009 | Samsung ML-2550 Laser Printer
Paper won't feed
You could try cleaning the rubber feed roller with a slightly damp rag, or even having feed assy replaced but you are right probally better off replacing it.
Dec 25, 2007 | Samsung ML 1430 Laser Printer
Samsung ML-1651N Printer
I have the exact same problem with my ML-1651N printer. It started out as an annoying problem that i solved by pulling the paper try out and then pushing it back in again. Now that solution doesn't work anymore.
Aug 23, 2007 | Samsung ML 1651N Laser Printer
Samsung ML-2550 Laser Printer Logo
177 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
