Question about Sylvania 6427GFG 27" TV
Tv shuts off after about 10 min
Sylvania tv shuts off after warming up
other day i blew air into it and worked fine the whole day so i figured let me clean it good to the back off blew off all the dust and then put it back together same problem?
  • mccoy46a Aug 17, 2008
    tv shuts off after 10 to 15se
    if take back off it work all day.
    i thank it in vcr. if put tape in vcr will run th 2hr
    tape.with back off it dose not cut off at al.i was vcr repair
    but be so long, i thank it have someing to do with light
    for work al day if back off as soon i put back on will cut off
    and if you put hand in vcr door you fell motor turning.
    so if you can hepl thank
    let know
    thank
    Aubrey
    Scholar:
  • 62 Answers
It's definitely some kind of cooling problem, or a cold solder joint that looses connection when things warm up. Can you turn it back on right away after it shuts itself off? You can purchase a freezing spray and use that to spray different areas on the circuit boards to find the problematic one, then you can get down to an individual component.
Posted on Aug 05, 2008
Hi i have a ready heater 170T i cleaned it last year to help out our main heater in our barn for when its get way to cold for our main heater to keep up so i turn this on when i am back there for the day...
Based on your description of the problem ............The part where you say "wont relight till it cools down" is a sign that the motor may be getting hot, the internal sensor in the motor is shutting things down for safety reasons. To find out run the heater til it shuts down then remove the cover. Feel the motor. It should be room temp or slightly warm. If hot- replace the motor with 102001-30.
Other possibilities would be a defective thermostat or temperature sensor. Eliminate these possibilities first.
Sep 07, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Mitsubishi 65 rear works fine yellow light starts blinking tv shuts off, when light stops can hit power and it could work fot 10 min or the next 4/5 days
All you need to know is that your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem, Take care.....
Oct 01, 2010 | Mitsubishi Televison & Video
Sylvania LC320SS8 32 in. LCD Television - Will not turn on
U have power on 10 mins,than is not the power supply board.Ur Tuner board is dead replaced that board.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish tuner signal board.
Feb 09, 2010 | Sylvania LC320SS8 32 in. LCD Television
Blows warm air, unpluged it for 2 days plugged back in blew very
Either the start relay and start capacitor or the Adaptive Defrost control is burned out. If you have a voltage meter we can test a few things like the compressor and the capasitor. The part number for the Adaptive defrost is 241508001 and found inside the fresh food compartment behind the control panel. I can help you locate the problem if you like. Let me know, Thanks, Sea Breeze
Jul 18, 2009 | Frigidaire FRS3R5EMB Side by Side...
Sylvania Picture on and off
it could be the mainboard is causing the trouble.
Jun 11, 2009 | Sylvania LC420SS8 LCD TV
2001 S-10, Blowing "ECM Batt" fuse after running for about 30 min
that fuse feeds power to fuel pump relay circuit that feeds pump could be defective pump,or damaged circuit wires that shorts out! and not a good idea to put higher fuse in circuit could cause more damage to circuit! but i know when your stuck, u do what it takes,so inspect circuit related to fuse,
Mar 10, 2009 | 2001 Chevrolet S-10
TV Dilemma
you have a stuck vhs tape in it.
Oct 20, 2007 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
RCA 20f510td
Sounds like a thermal breakdown of a componet. it could be in the main power supply regulaor supply or even a bad capacitor in the power or sweep supply. In some cases Zener diodes can break down and change values after warm up. In some cases also bad solder connections in the highvoltage section, or the power supply can cause this problem. It is a hard call without being able to look at the set. Just a few leads on where to go first. most likly a combo unit, such as this one , would cost you more then a new one these days. Good Luck PS Please dont forget to rate this thread.
Dec 09, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Sylvania 6427GFG 27" TV Logo
125 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
