Question about Creative Labs WebCam Live!
Webcam was working good,then started to show distorted picture.The picture looks like a film of oil over picture.I changed webcams and the problem still exists.Everything blends together in the picture like LSD trip.....I need help.
Creative pc cam 550 softwear
Posted on Jul 12, 2008
My 1996 mercury cougar XR7 3 8l 6cyl oil pressure dropped then started spraying oil from the oil filter seal thought the filter was cloged so I changed the oil and filter started it pressure went up then...
Two possible explanations come to mind. ON removing the old filter hat the oil filter gasket is removed from the base on the housing . Two gaskets are no good. Next over tightening the filter will distort the housing base and allow oil to escape past the seal. Always use a thin film of oil on the new gasket / seal to ensure that the rubber doesn't bind up when tightening up. The correct tension for the filters is on the case and is normally til it touches + 1/4 turn
Feb 16, 2014 | Cars & Trucks
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
Downloaded webcam and can take picture but video is upside down and distorted. What do we do?
Make sure you have the latest copy of Directx installed
http://www.filehippo.com/download_directx/
Launch your logitech toolbar - start your webcam using the Quick Capture menu (2 film frames) with webcam running open Settings menu ( 2 gear wheels) Click on Advanced tab or Owl picture and change the orientation here.
If the video is still distorted - uninstall the software and download again
Close all programs when uninstalling / downloading / Uploading
May 07, 2010 | Logitech Webcam
NEW 37" LG TV & PEOPLE LOOK FAT & SUV'S LOOK LIKE STATION WAGONS
Go to your TV settings and change the "Zoom" function (not sure if LG has same terminology as my Sony) - you can flip through different options until you get to the setup that does not "stretch" the picture to fit the screen - if certain shows are filmed in 4:3 format (or square), they will need to be displayed with two black bars on either side (letterbox) on a widescreen set so the image is not distorted or stretched.
Feb 01, 2009 | LG 37LP1D 37 in. LCD Television
Movement causes bluriness
I have a expensive webcam as my main one and a cheap webcam as my less used one and my cheap one does exactly the same thing
It is called Ghosting and there is nothing that can be done about it, it is just a poor quility webcam
Dec 26, 2008 | Logitech QuickCam Connect Webcam
Yellow line in middle of webcam pictures & other distortions
Hi
my creative web cam nx pro doesnt work, for win vista, could you tell me how can i resolve problem
Aug 10, 2008 | Creative Labs WebCam Live!
Can i use sony cybershot DSC-H9 as webcam
Just turn the dial wheel behind the shutter button to the picture where it show like a film camera. and you are ready to shoot video.
Below is the picture of the icon that you need to find.
Hope this helps.
Apr 18, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Scren split into 4 and in black and white.
Fergal0,
I am wondering if you have accidentally puy your cam in one of those fun modes like the ones that distorts the picture or turns it into 4 color pictures etc. I don't know what it is called on your model but the menu for this is called video effects. I know where it is on Logitech quick cams but not for yours. I suggest you just try looking at these setting options and see if you can make it change to something else and if so then you are in the right place and just have to find how to turn this off. Let me know what kind of camera you have and what kind of menus you have available if this does not give you a good hint.
Dec 02, 2007 | Logitech QuickCam Pro 5000 Webcam
CS330 picture size
Try this driver to see if you can alter sizes http://downloadfinder.intel.com/scripts-df-external/Detail_Desc.aspx?strState=LIVE&ProductID=460&DwnldID=3614&agr=N&lang=eng&PrdMap=460
Sep 05, 2006 | Intel Deluxe PC Camera CS330 Webcam
Creative Labs WebCam Live! Logo
97 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
