Question about Acer Aspire 5100 Notebook
PXE-E61 Media Test Failure PXE-M0F Exiting PXE ROM
I am getting this error, have checked the HD connection and everything is tight. After resetting the boot order to the default (HD, DVD, then Network) I still get this error. The odd thing here is that when selecting the boot order my HD and DVD models don't show up. They are represented by IDE-0 and IDE-1. After 10 or 15 reboot attempts (and one time where the screen was scrambled) the drives actually showed up and the models were listed in BIOS. The system booted up great and I thought that I solved the problem. Later in the evening I needed to install a Vista update which required a reboot and it started back up ok. Then, after closing the lid on the laptop, we get the same error again.
It makes sense to assume that the drives are ok but just aren't being recognized when booting up. Let me know if you could help me out.
Also, My HD was recently replaced and I occasionally hear something moving around in the computer. I sounds like a piece of plastic is loose and is either hitting one of the fans or a piece of the fan broke off. Not sure if this could of caused something to loosen up on the board and I have read of another person having the same issue with the error and a rattle sound. Perhaps this is just a coincidence.
  • Anonymous Jan 19, 2009
    i have the sAME porblem can any one give me the proper solution of this problem
  • 159 Answers
The laptop not recognizing the boot devices except the network boot that it found but there was no connection so it exit the pxe rom. first you need to open up the laptop and see what is running around inside maybe metal and your in for trouble if its metal maybe screw or so. second and this will hurt but you may need a new motherboard.but first lets get the object out.metal or plastic so you'll need to pull down the laptop and take the cmos battery out for abit .put the laptop back together replace the cmos battery leave out the hard drive and the optical drive (cdrom,dvdrom) then turn the laptop on wait for it to boot then turn off. replace cdrom with bootable cd inside restart. if it boots your in luck.turn off replace hard drive and restart. If all goes well and your able to boot to hard do this first download the bios flash for you laptop at toshiba site only at toshiba site and only your specific laptop model. read the readme file that come attached follow the instructions. then you can do you upgrade that you wanted to do all along
Posted on Jul 02, 2008
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
I get an error message on startup on my Acer Aspire 5100, it says Realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE...
It is beacuse your Hard drive is not detected on the computer properly.
Try resetting BIOS.
If that doesnt work, Check whether your hard drive is good.
Nov 28, 2010 | Acer Aspire 5100 Notebook
When trying to reboot I'm getting this pxe-e61: media failure
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
No bootable device -- insert boot disk and press any key"
install new NIC drivers from your laptop manufacture's site.
Nov 02, 2010 | Computers & Internet
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Mar 09, 2009 | Acer Aspire 4720 Notebook
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Acer Aspire 5100 Notebook Logo
2,328 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
