Question about Datacard Group SP75 Color Card Printer
Uper Duplex not holding card in place
I have two SP75 printers that have the same problem 90% of the time the uper duplex release the card too soon and the card will get stuck, it does not let the card go from the uper duplex to the lower duplex so the card will be laminated
  • 39 Answers
Early model sp75s have that type of problem. It can normally be fixed by replacing the clutch and duplex board. Very easy to replace. Be sure to be aware of the clutch spring when removing the duplex tray. Use the lower duplex assembly as a guide.
Posted on Aug 21, 2009
My Oki Printer jams every time with duplex unit installed, any idea?
Is there any message on the operator panel when the jam occurs? Where in the paper path does the jam occur? There are diagnostic tests in the printer but those are best left to an authorized service center.
Mar 17, 2015 | Oki Electric Industry C830DTN Laser...
How do you set the Lanier LD035 duplex unit?
Metal tab on right side of copier is bent and correctly touching the duplex unit interlock switch. Open the duplexer and notice the metal tab stick out. Put back to a 90 degree angle.
Jul 30, 2014 | Lanier Office Equipment & Supplies
Datacard printer SP75 plus error code error DM-00762 (Duplex Jam)
Open the duplex module cover at the back of the printer (1).
Release any cards stuck in the module (2). Make sure that the duplex
mechanism can move freely in the direction shown
For more help visit cbrtechsolutions
Jun 20, 2013 | Office Equipment & Supplies
Lower duplex jam error
It means a card is jammed in the top back part of the printer. You may need to open up the back hatch to pull out the card.
May 06, 2013 | Datacard SP75 Plus Card Printer
My datacard printer ribbon is supposed to get upto 500 images, but it is skipping every other color series so I am only getting 250 images
Every time you open the printer, it advances CMYK panel 01 to position the print head.This can cause loss of ribbon. Avoid opening the printer to the maximum you canoptimize your prints.
Jan 20, 2011 | Datacard Group Datacard SP75 Color Card...
I have a Lanier 5245. I am getting an error when
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
May 08, 2009 | Lanier 5235 Printer
Heater error in Sp75
Sounds like either the thermocouple or the heater went out. Was this the error code?
OP-01604 Thermocouple problem in L1 laminator
The comments in the service manual states:
- Check the thermocouple wire for damage.
- If the thermocouple was recently replaced, verify that it is not installed backwards
- Verify that the thermocouple connector is not unplugged or plugged in backwards
I would probably order a replacement part, call in your local DataCard service representitive or send it to DataCard for repair.
Oct 01, 2008 | Datacard Group SP75 Color Card Printer
No power
Hi Bret! Since this is a brand new printer, I would advise calling Lexmark. I'm afraid that you may void your warranty if you do much more at this point except for going back through the steps to make sure the duplexer was installed correctly.
1. Power off the printer and unplug the power cord from the wall outlet
2. Push the release button, and gently lower the front door.
3. Release the green tabs and lift up the image transfer belt.
4. Remove the cover over the duplex connector.
5, Remove the duplex option from the packaging. Carefully install the option into the printer, under the image transfer unit. NOTE: Make sure to line up the arrows on the duplex option with the arrows on the printer. Make sure the duplex option locks into position.
6. Lower the image transfer belt back into position. Make sure the belt locks into position.
7. Close the front cover.
8. Plug the printer back in, then power the printer on.
9. Try printing a few pages to confirm that the duplex option is securely installed. Then select the duplex option in the software and print a few double-sided pages to confirm that the duplex option is working.
The following link will take you to the instructions for enabling the duplex option in the software.
If the above does't work, I would strongly suggest contacting Lexmark for further help.
May 13, 2008 | Lexmark T630 Laser Printer
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Datacard Group SP75 Color Card Printer Logo
262 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
Jaime Hernandez
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
