Question about Mustek Office Equipment & Supplies
Unable to replace electric cable
Hi, I'm looking for a electric cable for my scanner as it went missing during a house move, cheers Bert
Thanx but my problem is solved, cheers .
Posted on Jul 03, 2008
Where can I get a replacement power cord for my Lexmark printer.
Hi
Looking at the setup and spec sheets, the power supply is built in therefore no separate power block (transformer) to worry about. The power cord on the set up sheet looks to be a "Figure 8". Check on the printer itself and if the socket looks like this:
then it almost certainly a standard lead that is used for many electrical appliances as well as computer peripherals, and should be obtainable at most electrical or computer shops. If you ask for a Figure 8 mains cable they should know what you mean but if have a way to take this picture with you - even better !
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 17, 2014 | Lexmark S815 Genesis AllInOne InkJet...
I have a number of Netgear FSM726S and FSM750S switches. During an office move some of the stacking cables went missing and I am trying to source replacements
Found some on amazon they look like the correct ones.
http://www.amazon.co.uk/NETGEAR-ProSafe-Stacking-cable-SFP/dp/B0047IMKCW
Thanks
Apr 07, 2011 | NetGear REPLACEMENT GIGABIT STACKING CABLE...
I've moved the computer & monitor to a new office & when all is connected up I get the message No Signal Input, check video cable, but all cables ie power & cable to computer are plugged in.
Make sure your monitor cable is screwed in on both ends. It is possible that your cable was damaged during moving, check for bent or missing pins on both ends of the plug.
Jan 02, 2011 | Computers & Internet
2000 passat ATQ, normally aspirated. Misfire #5. new coil pack, plugs, plug wires,good spark to #5 plug(visually checked) but still misfire #5 and no power during acceleration. What next? Thanks
Swap #5 injector with another one and see if the miss moves .
If the miss moves then the injector is faulty.
If the miss doesn't move do a compression test and get back to me .
Cheers
George
Jul 03, 2009 | 2000 Volkswagen Passat 4Motion
Indesit D63 Diashwasher Trips Electrics
Noise may be coming from faulty parts, but it also may be caused by improperly loaded dishes. heck your owner's manual for proper loading methods. Next, when the dishwasher is completely cool, look in the openings around the pump at the bottom of the dishwasher's interior be sure no implements or hard debris such as bones, fruit pits, or silverware are stuck in them.
Be sure your dishwasher is sitting level. Adjust the feet beneath the unit by screwing them up or down. If there are lock nuts on the feet, make sure they are tight.
A thumping or chattering sound during the filling cycle usually indicates that the inlet valve needs to be replaced. Unless you're handy with this sort of repair, this is a job for a repairperson.
Hardness (Grains) Tbsp. of Detergent
0 to 3 1 4 to 6 2 7 to 9 3 10 to 12 4
cheers!!!
Jan 14, 2009 | Indesit 24 in. D63 Free-standing...
My son got a telescope and we are unable to focus on anything.
Use the lowest magnification eyepiece which is the one with the largest number on it--- DO NOT use the barlow which will DOUBLE the magnification!
Go outside and focus on a distant object (during the daytime) and practice focusing the telescope. Move the focus know slowly in and out until you get a sharp image.
Jan 05, 2009 | Vivitar 50x / 100x Refractor Telescope
Denon D-90 Hi Fi - have lost interconnetion leads
Gents - not sure where you live, but try these UK links. The D65 was a similar system produced a year or two earlier, if the cable is 15 pin my bet is it is the same cable. Good luck, better look after my cables carefully!
http://www.chsinteractive.co.uk/electrical-components/misc/d90-cable-system-connect-13pin.htm
http://www.chsinteractive.co.uk/electrical-components/misc/d65-cable-system-connect-15p-d.htm
Nov 18, 2008 | Audio Players & Recorders
Scanner not working after being stored for a year
You must always 'lock' the scanner before you move! It is very sensitive. If you are scanning at 300 dpi, the scanner motors moves the platten by 1/300th of an inch and then the data is scanned. This is a continuous process, but you see only the platten moving.
There are are small plastic 'catches' on the back side. The top portion is 'press-fit'. Carefully remove every plastic catch and you can reach the inner parts. Most probabbly, the clacking noise is because the motor is not able to drive the platten. If you can reset it properly, then the scanner is ready! Ensure cables are not disturbed.
S. Mohan
Jul 27, 2008 | Canon CanoScan D1250U2F Flatbed Scanner
Init unable AF
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Sep 13, 2007 | Brother MFC-5840CN All-In-One InkJet...
83 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Tony
Mike
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
