Question about Pentax Cameras
I have used 2 different sd cards in my Pentax Optio T10 and both have become corrupt and I cannot view the images
    Scholar:
  • 101 Answers
If you have a card reader on your computer, insert the card, take note of the drive letter windows gives your card, then go to:
Start > Run > type "cmd" without the quotes, hit enter.
When the command window comes up, type "chkdsk y: /f" without quotes, and replace 'y' with your card's drive letter.
If you have windows Vista, check out this article
http://www.winvistatips.com/vista-chkdsk-a126028.php
Posted on Jul 02, 2008
I have a Pentax OPTIO S6, recently all camera function freezes whenever i insert an SD card, the screen turns on and I could see an image but ALL buttons do not work including the shutter! When I remove...
Does a different card work in the camera?
Can you read the card on your computer with a card reader?
and...check the little slider thingy on the side of the SD card, flick it up, try it, flick it down...try again.
check the SD slot on the camera, anything stuck in there? lint? dust? sand?
Blow it out with canned air.
Eliminate the card as a problem...hope it's the card then worry about the camera.
Good luck
TickMagnet
Aug 17, 2011 | Pentax Optio S6 Digital Camera
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
May 09, 2011 | Pentax Optio M30 Digital Camera
Pentax Optio T10,comes up with Card Locked, when turned on
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 23, 2011 | Pentax Optio T10 Digital Camera
My Pentax Optio S5z does not store images to SD
Copy your photos to the SD card in the camera. http://www.pentaximaging.com/files/manual/OptioS5z_web.pdf p. 136
Transfer all photos to your computer from your SD card, and then put the card back into your camera. Try looking through your manual to see if there are any other settings that are required in order to save photos to the memory card.
Feb 22, 2010 | Pentax Optio S5z Digital Camera
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
Memory card
Hi and welcome to FixYa.
Your camera will not work with an SDHC card. It must be an SD card.
Don't forget to format the card in the camera after you install it. Elsewise it won't work properly.
Thanks for coming to FixYa, and feel free to rate my solution.
Rob
Jul 28, 2008 | Pentax Optio T10 Digital Camera
Memory card not working
Not saying it is, but are you absolutely sure its not the camera software itself. Does it have any warranty? Is the card a new card and have you made sure that the TAB on left of SD card is not allowing READ ONLY. The tab flips up allowing the card to be formatted bit like the old floppy disks.
Apr 26, 2008 | Pentax Optio T10 Digital Camera
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
Apr 08, 2007 | Pentax Optio T10 Digital Camera
Bug in the Optio S40?
Somewhere I read to be careful using cardreaders, using your memory card in different camera's and managing your card via the computer. Appearantly all of these can corrupt your card. The advice is to hook your camera directly up to your computer to transfer images and perhaps it is wise to erase images through the camera's menu instead of via the transfer program of the computer. Try formatting the card using the camera's menu and see if the problem persists.
Sep 08, 2005 | Pentax Optio S40 Digital Camera
Cameras Logo
43 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
