Question about RCA Televison & Video
RCA Model #20F42OT will not turn on. The FPA is locked and I do not have the original remote. Without the T.V. on I can't sync in a new remote. How do I fix this problem!?
    Problem Solver:
  • 18 Answers
Very simple my friend just buy or find a universal remote look up on line the code for your tv for that remote and program it! Fixedya!
Posted on Jul 19, 2010
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
Dog ate remote where can i find one?
Hello
If you want to get its original model remote control; you have to contact the nearest RCA authorised service center at your town. You can't buy its orignal from nowhere else. A universal RCA remote control will work with it, but sometimes some buttons of it may not synchronised. So try to get its original model. Moreover, if by anyway this set happened to be in FPA lock, you cannot open the lock without the orignal remote control. A universal remote control, whatever it may be, won't work then. OK.
Sep 24, 2011 | RCA 20F512T 20" TV
I have and rca tru flat tv and my FPA lock is on... i have a brighthouse remote that im using on it but i need to know how to turn it off
Hello
Without its original remote control, opening the FPA lock of RCA will be difficult. Just try to get one new remote for this set or jut borrow it from any of your friends or relatives who own the same model set, just to open its FPA lock. After opening lock, you can use your brighthouse remote. You can open the lock with one amoung the following procedure.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Jun 27, 2011 | RCA TruFlat 27F520T 27" TV
I have a TruFlat RCA model # 27F520T have lost original remote and FPA lock is on how do I unlock without original remote? Dish universal remote not working to unlock tv, it will pull up menu but cannot...
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
Apr 30, 2011 | RCA TruFlat 27F520T 27" TV
How do i get the fpa lock off without the original remote?
Hello
It is very difficult to unlock the FPA lock of RCA, without it original remote control. Just try to get it from anyone amoung your friends or relatives; just to open the FPA lock. You can use it after that, with the help of any other univrsal remote control. To open the FPA lock, do one amoung the following till you get the correct process for your TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Mar 29, 2011 | RCA TruFlat 27F520T 27" TV
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
RCA 27V412T FPA LOCK ON & REMOTE LOCK
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Oct 02, 2007 | RCA 27F530T 27" TV
RCA FPA LOCK
Take the remote and turn the set on. With FPA (Front Panel Access, or Child Lock) on, the set will only turn on with the remote. Enter the menu, navigate to the page with FPA and set it to OFF.
Sep 02, 2007 | RCA 20F511T TV
FDA Lock
I have never heard of FDA lock. If you mean FPA lock, this is the Front Panel Access lock (also called Child Lock) built into the TV. To unlock FPA, turn the set on with the original remote, enter the menu, navigate to the page with FPA and set it to off.
Aug 21, 2007 | RCA 20F420T 20" TV
Televison & Video Logo
127 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
