Question about HP LaserJet 1010 Printer
Paper jam problam
I have a problam of paper jam after change a taflone roller.may its bad pressar roller.printer hp 1010.
    Master:
  • 479 Answers
No the tefflon is not fitted properly as you again open the printer and clean the tefflons upper side as any of the greece substance is got stuck up on the tefflon to cause this problem.also clean the pressor roller of orange/red colour with the isoprophyl and then slowly rub the liquid with very dry tissue.your pressure roller is perfectly alright as this paper jam problem comes very often after the tefflon is changed if it is not fitted and cleaned properly.
Posted on Oct 01, 2008
HP 1010 , paper jam near fuser assembly.
Remove left,right,top & back cover, #check paper sensor flag & flag spring, found any dis location? correct it.Most of the cases spring dis location observed (see the snap shot for easy recognition)#clean fuser paper out sensor as well as check sensor flag.#check fuser teflon sleeve.
Mar 22, 2012 | HP LaserJet 1010 Printer
Paper jaam
If old need to replace all rollers that feed paper - not an easy job
Try changing paper
Once you open the package paper attracts water like crazy and gets very humid and it will jam on regular basis
Try and keep your paper out of humidity
good luck
Feb 06, 2012 | HP LaserJet 1160 Printer
Hp laserjet 1010 has a paper jam and the paper was torn and a small piece has stuck on the printer... what shall i do... healp me please asap
You need to remove the small piece of paper. Try turning the rollers to free the paper, it will be tight to turn the rollers.
May 30, 2011 | Computers & Internet
Hi My HP printer is laserjet 1010 his problam is no take paper please advise me how to solve problem Thanks Ali
With just a few pages in the tray, send a job to the printer and at the same time look into the printer where the paper is. You will see if the paper pickup roller turns or not.
If the paper tray rises to where the pickup roller is and the pickup roller rotates then the problem is that you have a worn or dirty roller. The roller can be cleaned with a number of liquids but try warn water on a cloth first. Also if yiou take the toner cartridge out, you will have clear access to remove the roller or clean it. I have also removed the roller and then rotated the rubber tyre a little so that the worn part is not in use.
May 29, 2011 | HP LaserJet 1010 Printer
Hp laserjet 1010 printer without ant error it is doing paper jam evrt time wht is problam?
try uninstalling then reinstalling the ink cartridge, if problem still exists consider visiting the nearest service center..
Aug 28, 2010 | HP LaserJet 1010 Printer
Paper jam
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
Apr 18, 2010 | HP 1010 Plain Paper Inkjet Fax
Paper jammed.sheet stuck approx 9cms out at top.
The problem is the fuser. Lower pressure roller is damaged. Possible wear and fuser fixing film.
can change throughout the whole fuser
RM1-0661-040 ---- HP LJ1010 220V Fuser Assembly
RM1-0660 ---FUSER - 120 Volt Fuser Assembly
or parts of this
http://www.precisionroller.com/search.php?q=hp+1010&x=12&y=5
FUSER - Lower Pressure Roller :  RF0-1002
FUSER - Fixing Film Replacement Sleeve : for hp 1010
good luck
Dec 13, 2009 | HP LaserJet 1010 Printer
Paper jam in laser jet 1010
Try this support document from HP:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00028456
Dec 10, 2009 | HP LaserJet 1010 Printer
My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
Reinstalling the printer is related the Software.
If the paper gets physically jammed than its the driver setting issue or hardware issue.
Check if two sheets get jammed or only one sheet.
If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
Jul 01, 2009 | HP LaserJet 1010 Printer
Paper gets folded at the edges
Clean damaged roller with the special liquid for recover rollers )) That's all))
Nov 17, 2008 | HP LaserJet 1010 Printer
HP LaserJet 1010 Printer Logo
134 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
