Question about Samsung HCL4715W 47" Rear Projection Television
SAMSUNG HCL4715W THIS ITEM WAS DAMAGED BY LIGHTNING. WHAT MODEL IS COMPLIMENTARY TO THIS - SAME SIZE, FEATURES, REAR PROJECTION. THERESA, ADJUSTER TRAVELERS INSURANCE
  • Samsung Master
  • 8,617 Answers
The HCL473W, HCP4752 are basically the same set same features. The HCL models like the HCP are rear projection. Unfortunately Samsung no longer manufactures the rear projection CRT models they are only available in the DLP rear projection with the closest comparable model currently available for a new replacement would be the HL50A65 which is a 50 Inch 1080P suggested retail 1299.00 If I can help you further please let me know. Also new replacement chassis are available for the HCL4715W.
Posted on Jul 02, 2008
Fix the 3d look on my rear projection samsung model hcl4715w. it is a 2001
Read Chapter 3 about adjusting the convergence controls. These are to do with the alignment of the colours. It will help you fix the 3D look.
TVs
Sep 11, 2014 | Samsung HCL4715W 47" Rear Projection...
Convergence board for a HCL4715W? Which one?
It will be the one that has big black ICs STK394-020 for Parts callMats 1-800-628-1118 also there is 2 resistors 2.7 ohm near STKs replace if Bad.
Sep 25, 2009 | Samsung HCL4715W 47" Rear Projection...
Green out of alignment on samsung rear projection tv
LOOK for 3 parts that start with STK (BLACK THINGS THE SIZE OF A MATCHBOOK) then replace all 3 (ebay) also look for some green coils that may be burned. If you SEE THE STK's then your in luck, as 95% of them are bad.. Please rate!
Mar 30, 2009 | Samsung HCL4715W 47" Rear Projection...
Red is outta focus on a samsung model#hcl4715w
replace the two convergence ICs and also check the 3.9 ohm resistors
Mar 15, 2009 | Samsung HCL4715W 47" Rear Projection...
Samsung 47 inch Rear projection HCL4715W
Only If they are burted up,and no you should be able to use your heat Sinks.Rember to CK low ohm resistors samsung has 3 that can and do go bad. 2.7 or 3.9ohms
Jan 07, 2009 | Samsung HCL4715W 47" Rear Projection...
Your reply to the Samsung 47 inch rear projection not turning on
As long as you do not accidently solder wrong connections together you should be OK. Make sure all solder is to same circuit.
Tv will not turn on
If your convergence ICs are bad set will not come on 1 of the ICs controls Off/on STKs big black ics replace both STK392-020s use 040s For Parts call 1-800-223-3205. www.electronix.com
Jan 03, 2009 | Samsung HCL4715W 47" Rear Projection...
Service manual
http://downloadcenter.samsung.com/content/UM/200306/20030618174051718_AA68-01509D.pdf
Nov 17, 2007 | Samsung HCL4715W 47" Rear Projection...
Internal Screen Adjustments No Response
thr focus block assy.has the screen and focus controls on it it about 3"x3" in size has red wires attached to it and one feeding form the flyback transformer to it.
Aug 29, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
102 people viewed this question
Jerry Greenberg
Jerry Greenberg
