Question about Sony Ericsson K610i Cellular Phone
K610im my k610im is not getting started when pressed the on button it gives five blinks of red light
  • 1 more comment
  • Anonymous Aug 03, 2008
    everytime i try to on my phone,it only shows five blinks and it does not turn on.
  • lionofgod57 Dec 20, 2008
    my k610i phone doesnt switch ON. it doesnt even charge. when i plug the power on the socket it just shows 5 red blinks on its power indicator. it is supposed to show the charging indicator but it doesnt. hw can i make this work!? i need to access my phone record.
  • rgersten Dec 27, 2008
    when i try to turn the phone on by pushing the ON button, the light flashes red for a second then stops. the phone does not turn on. removing the battery and try to charge the phone DOES NOT solve the problem. Holding the ON button for 5-10 seconds also DOES NOT solve the problem. please help.
Http://www.esato.com/board/viewtopic.php?topic=158932
try the link above for a solution.and or leave the battery out for an hour or more.hope u get it working again
Posted on Dec 28, 2008
    Problem Solver:
  • 18 Answers
Check if the battery is fully charged.also try removing the battery and put it back and try switching it on
Posted on Jul 26, 2008
The solution posted on Jan 14, 2009 by stk_id WORKS and is easy to do. The only recommendation I would add, is after installing the USB drives and tool software, remember to restart your computer. Once restarted, follow the process mentioned in the web. My phone is working again. Thanks stk_id
Posted on Jan 15, 2009
  • 3 Answers
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Oct 14, 2017 | Sony Televison & Video
Exchange oil lighting
  • There are a couple different Grand Am's that each reset their own way.
  • I am pretty sure yours resets by ---
  1. Get in the car and put the key into the ignition.
  2. Turn the key on (no start).
  3. Wait five seconds.
  4. Now press the gas pedal to the floor all the way three times in a row.
  5. Wait five seconds and the light will disappear.
  • The other way for some of the Grand Ams are ---
  1. Get into the car and open the fuse panel access panel.
  2. Find the red "reset" button.
  3. Put the key in the ignition to on (no start).
  4. Wait five seconds.
  5. Now press the red "reset" light for ten seconds and the light will blink than go off.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 09, 2011 | 1999 Pontiac Grand Am GT
I can't get the KX-TGA405B Extender to fine the base on the KX-TG4033 phone? I have tried moving it to other locations in the house and outside, and all I get is the status light blinking red. The ant....
With the repeater connected to its power block plugged into an outlet, find the tiny square button on the back of the repeater. It's below the word 'Program.' (The instructions do not mention the Program button at all! ) Press the button. The two LEDs on the repeater will flash red continuously.
At the base, press the 'Locate' for five seconds and release it. Then press it briefly once. Next, press the 'Locate' button again for five seconds and then press it briefly once again.
The two LEDs should now show solid green indicating that registration was successful.
After the process has been completed, the registered repeater may be relocated to the desired area. If the lower LED remains red, you will have to find another place to put the repeater. A location where the LED is green would be best but mine worked well when it was amber.
Oct 28, 2010 | Audio Players & Recorders
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
Uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
Feb 07, 2008 | Uniden Cordless Phone
Sony Ericsson K610i Cellular Phone Logo
160 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
