Question about Visioneer OneTouch 8900 Flatbed Scanner
Driver for vsioneer OneTouch 8900 for Windows 7
    New Friend:
First install your regular drivers for your scanner and then turn it off.
http://support.visioneer.com/products/9420/downloads_1.asp
Download drivers for your scanner from the page above, don't mind it is not the same model - it will work. Also it will work with One touch 8700 Visioneer windows 7 x64 with the drivers for 8900 and 9420.
Next, install the driver, and then open Windows Explorer i locate files at:
C:\Windows\twain_32\VizScan\8xxx. Copy them all to:
C:\Program Files\Visioneer\OneTouch 4.0\9420 Driver
Next step is to tell your computer exactly what driver to use by right clicking on My Computer in Windows Explorer, then Properties, and then Device Manager. Now, turn on your scanner and it will appear on the list. Right click on it and select Properties. There click "Browse my computer for driver software" and then "Let me pick from a list of device drivers on my computer" and browse to: C:\Program Files\Visioneer\OneTouch 4.0\9420 Driver. Select OT_9420.inf and install it. Now u can use your scanner on Win7 and enjoy! Don't mind the different name! ;)
All the best to ya all
Posted on Sep 09, 2012
    New Friend:
Very Helpful, now I don't have to buy a new scanner. I found that I also needed to upgrade my old Paper Port 7 so that it was compatible with my 64 bit computer. I found a great free alternative, XnView (http://www.xnview.com/en/xnview.html) that works perfectly. Now I am better off than before. Thanks so very much for your help.
...Maria
Posted on Jan 21, 2013
    New Friend:
Ok tank
Posted on Dec 12, 2012
SOURCE:
Window 7 driver of visioneer 9320
This model is discontinued from OEM. So, it will not work on Windows 7. For more information, please visit the following links:
http://support.visioneer.com/products/9320/default.asp
http://support.visioneer.com/KnowledgeBase/Articles/VIS1493%20-%20Updating%20Your%20Scanner%20Driver.asp?ScannerModel=DM3115&bit=32
Hope the above information is helpful.
Thanks & regards,
Scancare
Aug 16, 2012 | Visioneer OneTouch 9320 Flatbed Scanner
Can you also Fax with this One Touch 8900 ?
This is only a scanner. To Fax, you will need a separate fax machine or fax modem. If both the scanner and fax machine are connected to your computer, you will be able to scan the document and then fax it from the computer. (Depending on your OS/software, this could be easy or take several steps. For Windows Vista and Windows 7, you can use Windows Fax and Scan to do both steps. (However, the program doesn't scan to PDFs.) Paperport will also send a scanned document to an installed fax option. PaperPort is part of the third-party software that came on the CD with the scanner.)
Documentation for the Visioneer OneTouch 8900 is available here: http://support.visioneer.com/products/8900/default.asp .
I hope this helps.
(There are some email-to-fax and web-to-fax options but I have not reviewed them.)
Jul 14, 2011 | Visioneer OneTouch 8900 Flatbed Scanner
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
Jan 03, 2011 | Visioneer OneTouch 8700 Flatbed Scanner
How can i install visioneer one touch 8900 usb scanner in Windos 7?
The 9420 visioneer Scanner driver will run the 8900 scanner.
first,go to visioneer and download the .MSI file for the 9420. Run it. The driver files will be found in directory: C:\Visioneer\OneTouch 4.0\9420 Drivers.next, find the 8900 drivers.they will be in c:\ Windows\twain_32\vizscan8xxx. open the file and look for rtscan.dll Rename it old rtscan.dll.if you can't find them,either use Device manager to show you where they are. or you can reinstall the Driver(Xp\2000\Me\Win 89 from Visioneer site. Rename the rtscan.dll file which will be in the twain_32 folder(see above).
copy all the files in 9420 Driver file to the c:\Windows\twain_32\vizcsan8xxx folder. turn your scanner on.windows should find the drivers and install the scanner.
Sep 18, 2010 | Visioneer OneTouch 8920 Flatbed Scanner
I believe thaT INCOMPATBILE WITH wIN 7! i'AM TRYIN TO ADD THE SCANNER TO A WIN 7. IS IT POSSIBLE?
According to this page:
http://support.visioneer.com/products/5800/downloads.asp
The scanner works on windows 98, ME, 2000 and windows XP. There is no driver for Vista or for Windows 7.
Feb 09, 2010 | Visioneer OneTouch 5800 Flatbed Scanner
Visioneer OneTouch 5820 USB for windows 7
ok guys here is the fix for vist and or windows 7 to make your scanners work
1. put your cd in the drive don't let it autorun
2. goto my computer then right click the driver that has your install disk in it
3. click open
4. then fine the drivers folder and open it
4. the file you see should be your driver for your scanner the number on this file should be the modle # of your scanner
5. right click that file then click run as adm. allow any and all pop up's
6. after the install is done restart your computer
7.after the computer reboots go back to my computer and open the driver that has you install disk and open it (do not do auto open) like for this file start32.exe and right click it then click run as adm. allow any and all pop up's (you may see something saying in any one of the steps that the driver or software u are trying to load dose not have a signature always click ok, allow, or indtall this sofe ware is old so it dose not have a signature)
8. after the install is done reboot your computer goto control panle and open it look for systems and open it goto device manager open it then look for your scanner it should not be hard to fine it's the one marked with the yellow flag
9. right that file then goto properties then click on it then goto update driver ( do not click driver update software in the same menu with properties) another menu will open up click on update driver it's just below the driver details box
10. now windows will update your driver when done restart your computer and y should be good to go
Jan 26, 2010 | Visioneer OneTouch 5820 Flatbed Scanner
Does the Visioneer OneTouch 7100 work with Windows 7? Where can I find a driver?
I scanned by cannon scanner (canoscan D646u ex).Suddently the error message appeared that Release the lock switch, detach the usb cable and reconnect.close the scanner driver. What can I do ?
Jan 11, 2010 | Visioneer OneTouch 7100 Flatbed Scanner
I have a visioneer onetouch 8900 and my new computer has Windows 7 on it. Visioneer does not support it anymore, where can I get a driver patch to make it work?
.the Visioneer 9420 scanner program will run the 8900. You can run Visioneer 8900 in Windows 7, and Vista. uing thedriver for9420. Please type 'Can I run Vissioner 8900in vista?
you should see a web site for icrosoft forums that gives the steps involved to get your scanner to work in both Vista and Windows 7.0
Dec 23, 2009 | Visioneer OneTouch 8920 Flatbed Scanner
Visioneer OneTouch 8900 Flatbed Scanner Logo
2,636 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
