Question about Cooktops
Looking for Cause of Fault Code on GE Range top JP939
Range top model JP939 is reporting Fault Code F113. Additionally, one of the 4 hot burner indicators is on and will not turn off. All burners are off and cool. Model is JP939
  • 3 more comments
  • Anonymous Aug 04, 2008
    Received F113 for the left frount burner on a GE Profile Glass Cook Top Range Model # JP950
  • Anonymous Oct 11, 2008
    Exact same as his
  • Anonymous Oct 28, 2008
    I have the same problem.
  • garydma Jan 06, 2009
    I have the same problem on a JP980. Anyone found a solution?
  • Anonymous Jan 17, 2009
    Same problem Left front burner safety indicator says it's hot even though it's cool. Try to turn on that burner and it immediately goes to alarm mode flashing F113. Tried cutting power to the cooktop but no difference.
Have SAME EXACT issue - F113 on Left burner. Indicator says HOT and not even on. Called a service company (NOT GE SERVICE). They said the Element Radiant is no good and must be replaced. Part is quoted as $323.98 !!! What a rip off from GE !
Posted on Apr 02, 2010
GE F105 error
According the service guide, an F105 error is "Zero cross failure"
Correction action is:
(1) Recycle power to the cooktop (i.e. turn breaker off and on)
(2) If fault persists, test the line voltage supplied to the cooktop at the wall outlet. Voltage should read from 175VAC to 265VAC. If it does not, there is a problem with the power being supplied to the cooktop.
(3) If fault persists, replace power board
(4)If fault persists, replace main (Logic) board and recalibrate elements.
Mar 31, 2013 | GE 30 in. Profile JP939 Electric Cooktop
GE profile JP969 fault code F113
I took the cooktop apart I removed the terminal from the main electronic board . The left front burner has 2 white wires and 2 yellow (my case). The 2 white wires lead to the RTD sensor.With an electric meter set on OHMS check continuity between the two wires leading to the RTD sensor .If the reading is more than 1030 ohms is good if not than you need to replace the whole burner that comes as a complete unit with sensor and ribbon heating element.I found it on line for $114.00 +shipping.I wish they sold only the sensor but it would've been too cheap and not worth it for the makers . All connections to that burner are very easy put back together . Some suppliers may ask for as much as $175-$195 for the complete unit .
Apr 11, 2012 | GE 36 in. Profile JP969 Electric Cooktop
How to replace a radiant burner element wb30t10062 on a cook top not a combo, oven and cooktop
Search for my solution for a replacing the element on a JP939/JP969. That should help for similar GE models.
Sep 10, 2011 | GE 30 in. Profile JP939 Electric Cooktop
Error 108
According the service guide, an F108 error is Line Monitor Failure
(4) If fault persist, replace logic (main) board
Search for my solution for replacing an element (JP939/JP969) for the basics to open up the unit.
Apr 09, 2011 | GE 30 in. Profile JP939 Electric Cooktop
I get an error message F113 for one burner
This indicates failure (open circuit) of the left front temp sensor. You can search for my solution for replacing a element on a JP939 and JP969. Will likely require replacement of the element (~$160).
Mar 24, 2011 | GE 30 in. Profile JP939 Electric Cooktop
On light comes on but burners don't get hot.
Dear friend,
sounds like your problem could be either burnt out element or wire to the element or both. I am qualified in saying this as i am an electrician & have experienced these problems many times in my busness.
Cheers
Jim.S.
Dec 25, 2010 | GE 30 in. Profile JP939 Electric Cooktop
GE profile JP939 flashing F152, how do I fix?
F152 means the right front burner has failed, the sensor in it is bad, the burner will need to be replaced. If you go to the following web page, and pick out your exact model number, you will see diagrams and parts lists that will help you get this fixed. You can order the element from that website, if you choose: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JP969 Good luck, and hope this helps.
Nov 28, 2010 | GE 36 in. Profile JP969 Electric Cooktop
I get a hot surface light when the burner is off and has not been used. My wife said she got a fail code but was unsure of the problem and did not write down the code. I have cycled the breaker on and off...
This is usually caused by one of the infinite switches. They are easy to check and replace. You will need to remove the cook top and disassemble to access the switch assemblys. Here is a link that will walk you thru testing the switches http://appliancehelponline.com/infiniteswitchvideo.html You can also enter your model # for diagrams and illustrations of your model.
Jul 16, 2010 | GE 30 in. Profile JP939 Electric Cooktop
F113
I have the same problem. I had a repair man here and he said the main powder logic board ( WB23T10014) was the problem, it would cost $757 to fix. I ordered the board for $230 and installed it myself but still have the F113 problem.
Jan 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
What does F113 fault code mean for a GE Electronic touch control
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 25, 2009 | GE 36 in. Profile JP969 Electric Cooktop
Cooktops Logo
1,078 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
