You posted under Intermatic ST01C battery-operated in-wall timer.
This is not a plug-in timer.
You say you have a timer for controlling a lamp >> that sounds like a plug-in timer and not an in-wall timer.
If this is not your timer, or you are uncertain about which timer you have, then add a comment and describe your timer in detail including buttons and anything you can remember about setting times.
If you have the ST01C timer, instructions are lengthy and best done with accompanying images:
See instructions with images:
http://waterheatertimer.org/ST01C-program.html
If ST01C was programmed correctly in the past, and the timer stopped working, then battery might need replacement, or timer might be bad. If battery is dead, your programs are still saved inside timer, and all you do is reset current time.
If you do not have ST01C, the following page will help identify your timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment and I will help for free.
Fixya also offers phone support for a fee, and that person can walk you through the steps. You must identify timer for that specialist to help, since each timer is programmed differently.
