Bose Acoustic Wave  (32022) 5-Disc CD Changer Logo
Posted on Dec 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Acoustic Wave Music System - One of 5 CD's seems to be stuck and won't eject. Just flashes "changer" in digital window. Tried unplugging, but did not reboot.
Jose Cada
Level 3:
  • Master 3,530 Answers
  • Posted on Dec 18, 2010
Jose Cada
Master
Level 3:
Answers
3530
Questions
Helped
964796
Points
9839
Welcome to Fixya
Sounds like you have a faulty tray mechanism inside the unit. Unplug/plugging in the unit from thewall outlet should solved the issue. If same thing will happen then you need to have the unit opened and check the mechanism of the cd tray.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
1helpful
I installed the update disc into the Wave Music System and it seemed to eject within about 5 seconds rather than the suggested 20 secs. How do I know if it did the update?
wilf? this is a wave radio and cd player, what update you're trying to accomplish when the unit is in working condition in the first place?. There's no such thing as an update...
Cd changer not working
you must open the carrousel or magazine, and dissamble the cd. and then you must LUBE the gear and shaft with little vaseline or grease for to properly function+ replace the belts worn very important. and fix it.
God bless you
2helpful
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Thanks.
Update CD Disc is stuck in wave music player, it didn't update anything for the multi changer and it will not eject. Stuck in "Loading" cd mode
Have you tried unplugging the player, waiting several seconds and then plugging it back in?This may reset the euipment and cause it to eject the update disc. Be sure to wait when it says wait. Do not force anything. You may damage the unit.Is this an entirely new system? If it is, find your manual and paperwork and call the company support number immediately.
1helpful
Can the new 5 cd changer work with the older Bose
It will work as a manually-operated AUX input, but since there was no remote for the original system so that function won't be available.
2helpful
I have a Bose acoustic wave muti-disc changer.i have 5 disk in changer,i cannot eject any disk,& it looks like its hung up on # 5.non of the disk will play. Thank You-
I called Bose service. Jason said to unplug for 1minute then plug back in. If the changer does not reboot and operate properly....you call Bose service. They will exchange your cd changer for a new one.
$75 plus tax and return your cd's to you. They will give instructions for the exchange when you call.
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • 3helpful
    Bose Wave Music Sys & 3 CD Changer
    I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
    Top Bose Audio Players & Recorders Experts
    Grand Canyon Tech
    Grand Canyon Tech
     Grubhead
    Grubhead
    ZJ Limited
    ZJ Limited
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
