I have a Fellowes Shredder that needs a new plastic gear. Fellowes tells me that they cannot locate the part due to the age of my shredder. The gear itself has # 38741 imprinted on it. Is there anywhere I can get this particular gear for my shredder?
-   The teeth on the nylon geared cogs have broken, I would like to know if I can purchase new gears and from which company. My shredder is a fellowes p55c and not very good at all, this is our third machine and will not be buying anymore fellowes tat.-   PHLEP
If this unit is worth it to you, you can build your own gear. Here is a link to get plastic repair materials to make plastic parts. This site also will have materials for repairing plastics.
Another possibility is to search Ebay for a unit like yours which has other problems. Never can tell... it may be there. Make sure you ask for the model of the unit in your search (on the NET as well. The serial in this case is not needed.
Comments:
Jul 28, 2008
- Sorry, I forgot the link to the plastic repair.
http://www.plastex-online.com/
Jul 28, 2008
- Here is one that I have used, and ordered plastic repair supplies from. Great site, and videos of how to as well.
we have an intimus 430 se that is having keypad problems.(I think!) It will run in reverse but not...
(More)
we have an intimus 430 se that is having keypad problems.(I think!) It will run in reverse but not forward. Do you know where we can get service in central Illinois?
Paper will only feed through shredder teeth if I press in the plunger / switch the paper normally...
(More)
Paper will only feed through shredder teeth if I press in the plunger / switch the paper normally hits. Paper starts to feed / shred then stops until I press little white plunger switch. What is wrong?
it has been working fine, but today, I emptied the basket and replaced the shredder unit, and it...
(More)
it has been working fine, but today, I emptied the basket and replaced the shredder unit, and it isn't working at all
