Question about Hotpoint TDC32 Electric Dryer
How do I check the switch? Where is it located.
Replaced both Thermal cut outs, light stays on almost all of the time & when on the heaters won't come on.
Help please
    Novelist:
  • 161 Answers
1. see if you have 220 at the plug, the dryer will run on 110 but won't heat.
2. Check the heating coil, it could be broken.
Posted on Dec 16, 2008
Dryer is blowing out cold air
Chance is the TOC is gone this is thermal cut out that is located at the back there is two of them one has gone but you need to replace both , parts are around £ 15 for the kit......If you have amultimeter you can see which one has gone, TOC should show closed circuit...............Good Luck
Jan 08, 2011 | Hotpoint TDC32 Electric Dryer
Dryer not heating
When the dryer won't heat it is the thermostat/thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help....
Dec 28, 2010 | Hotpoint TDC32 Electric Dryer
Heats up slightly hotpoint condenser TDC32
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
e76jy
Feb 18, 2010 | Hotpoint TDC32 Electric Dryer
When I turn the button to cut the dryer on, it's making the noise but it's not staying on and it's not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
zvcbzcvbv
Nov 11, 2009 | Hotpoint TDC32 Electric Dryer
Empty water light stays on
Remove lower left filter,and washout under running water, reach into the opening and clear out all fluff and gunge, get a plastic bag tie or similar, and feel for and locate small hole at rear of compartment and poke clear with plastic
Make sure the air vents are clear back and front and try again, if still showing light then probably the float switch is sticking or faulty, this involves a complete strip down of dryer to fix.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 keeps switching off after a short while
Yes, it sounds like the relay is the prob
It is located at the top behind the console panel.
It is a clear plastic covered box about 3" long, and held in place by 2 screws.
Changing this should solve the prob.
Thanks.
Dec 29, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint tdc32
How do I put a new belt on my tumble dryer
Nov 08, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint dryer TDC32
check the switch where you remove the tank towards he bottom
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Aquarious condenser dryer
hi there the problem you have there is a faulty start relay located behind the control panel accesed by removing lid.
part no for relay is C00095530
Dec 08, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
143 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
