Question about Packard Bell Computers & Internet
The power jack on my Packard Bell Eastynote s4 had been pushed inside the casing of the laptop. The power cable will not fit into the jack because it has been pushed in. Any idea how I remedy this?
    Sergeant:
    Champion:
  • 317 Answers
I would suggest opening up the case, and re position the jack, and finding some way of making sure it doesn't move after that (duck tape anyone)
Posted on Jul 02, 2008
Packard bell alp ajax c3 power button does not work.
You may well find the switch is broken or damaged in some way. To get to it means you must take the case apart.
This may help;
http://www.youtube.com/watch?v=1po_tEMQEPs
Dec 12, 2013 | Packard Bell Computers & Internet
I cannot get any sound on my laptop
try to download DRSUP, dvd its a large collection of driver for allkinda windows version. hopefully your sound card driver list on that dvd.
Oct 11, 2013 | Packard Bell Ac Adapter For Easynote Tj61...
Packard Bell netbook wont start up
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Feb 27, 2011 | Computers & Internet
How to install memory for Packard Bell Easynote s4
open the cover at the back, be sure no power adapter is connected and battery is remove.
Feb 18, 2011 | Packard Bell Computers & Internet
My power supply for packard bell blew up due to much power,so i
The style of power supply is different from a universal power supply. A universal power supply won't fit in the slot properly.
This website has it for fairly cheap:
http://www.partstore.com/GetModel.aspx?MfgName=Sumitomo+Group&BrandName=Packard+Bell&ModelNumber=845061&Page=1&SortBy=idealitemnumber&SortDirection=desc
Apr 23, 2010 | Packard Bell (190169) Power Supply
Packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
Mar 07, 2010 | Acer Computers & Internet
My packard bell easy note laptop keeps flashing off,i have to put the top right back then slowly forwards again so it works
There is a ribbon cable connecting things together.
Sometimes they crack.
Sometimes they are in the hinge area and may be able to be replaced
but would be expensive at a shop and a bit technical.
There could also be dirt or a sugar liquid like pop or coffee spilled inside the on/off or hinge switch (a little switch that is pushed when the laptop closes, usually near the jam or could be inside casing.) and this could be causing a short.
Probably ribbon cable, may not be able to be replaced! without replacing screen. Here's hoping for you. This is generalized information and not P.Bell specific..
Need more info as to whether is just screen or whole laptop going off/on.
Good luck, hope this helps some.
Feb 23, 2010 | Packard Bell iMedia SL 9553 (P660401806)...
Help me Ive lost the Audio drivers for Packard Bell Easy Note S4
hello there go to the packard bell website on the top there is a link for support click on that then enter your serial number for the notebook and it will give you support including drivers.
Jan 21, 2010 | Packard Bell (030069) Sound Card
Packard bell ixtreme
Sure. The plastic front usually comes off and then you can install it from the front or slide out the power supply(with wireing stil attached) , if it is in the way to instal from the rear. When running , if a older computer,as you didn't state the model number, with ribbon cable,set one to master and the other to slave,if on the same cable.
Jan 14, 2009 | Packard Bell (ATXMH28AP) Full Tower Case
Speakers
Packard Bell (160248-01) Computer Speakers with a 12 volt power source worked OK,
Tried a 9 volt and it also worked.
This pair of speakers is grey with a barrel design. The mounting surface placed flat is approximately 10.25 inches by 3.75 inches. Each end has a rainbow design with a depth of 2.75 inches. By placing with the mounting surface flat on your desk gives you an out of the floor design. The front edge from the desk to the bottom edge is 1.5 from the surface to the top edge with a 3.75 inch. Suggesting you may mount them under your desk, on the side by your legs or stand them on each side of your screen.
I am told they come in white and black also I found them rather large for what I need but your decision is you should be happy before buying a pair.
Jun 23, 2008 | Packard Bell (160248-01) Computer Speakers
Computers & Internet Logo
59 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
