Start up troubles
I just purchased a laptop last night i installed my word and antivirus, this morning it wont even start up a "start up repair" screen pops up. It also wont allow me to do a pc restart, or system restore. What can i do?
  • golirene Jul 02, 2008
    Acer TravelMate 3260AWXMI
    Genius:
  • 1,019 Answers
What you,ll need is a system restore CD.
Usually supplied with the Computer/Laptop.
Your only other option, is to enter the systems BIOS Setup if possible, and instruct the the computer, to first boot cd/dvd rom drive, with your windows or operating system cd in, and carry out a new installation. this could be a missing file/driver issue. or failed RAM ( Memory ) Which can only be determined by listening for Beeps at system startup.
Mike @ Compurepair.
Posted on Jul 03, 2008
2001 chevy impala wont start just make a click sound started fine last night this morning nothing pls help its not the security thing either had that fix on the recall
Before you trouble shoot a car always charge your battery. It sounds like you have a loose Battery Cable to the Starter to me. This has happen to me that's how I know. To confirm this pull on the positive battery cable while someone else tries to start your car. Did it start? If it did not start then it's between your Battery and your Starter. Let's now check your Battery. Fully charge it again and make sure you have 12.6 Volts if your Battery does not take a charge it has a bad cell and needs changing. If your Battery turns out good then you have to check your starter or Solenoid and if one is bad change them both. Remove it and have an auto store check it to see which one is bad. I hope this helps you out. Let me know how you make out.
Jan 09, 2015 | Cars & Trucks
H3 hummer wet and wont start
I'm not a Hummer mechanic but I would say it is related, and I would go on to suppose that the fuse panel got wet and caused your troubles. I hope you had a reputable glass shop install your glass because they will be responsible for any repairs and damages.
Mar 18, 2014 | 2006 Hummer H3
2001 highlander engine skipping cel on
Chances are its a spark plug or coil. You should have a trouble code in the computer for the cylinder in question. The flashing light means the problem was serious at the time.
Jul 05, 2013 | Cars & Trucks
Trac off light
Most likely a loose sensor on the drivetrain more specifically the traction control system easiest to just have it scanned for codes buy a good repair manual like. Haynes or chilton and replace or repairing indicated part from the trouble code
Jan 05, 2012 | 2000 Toyota Camry Solara
Turns over ok wont start.ran ok last night this morning wont start. new clutch last night and brake lines.
While doing the clutch you more than likely unplug the fuel pump wiring harness or the crankshaft sensor and this wiil cause the truck not to start. Check under the truck for a unplugged wiring harness and reconnect it and I am sure your truck will start.
Apr 20, 2011 | 2002 GMC Sierra
Windows wont boot up when I turn on my Toshiba
You need an antivirus program to be installed after installing your operating system. Do it in safe mode. If problem persists let me know.
Jul 10, 2009 | UltraLast FOR TOSHIBA SATELLITE A50/55...
My acer laptop keyboard isn't working!
my acer 5515 laptop keyboard wont work
Jul 02, 2009 | Computers & Internet
1991 dodge carvan wont start cold
you have water in the fuel line
Mar 05, 2009 | 1991 Dodge Caravan
Cannot start up my laptop since in done an update
Try booting into "Last known good configuration" it is on the same screen as Safe Mode, if that does not work, you can try to run CHKDSK /r from the windows install CD, just choose "Repair" in the option, if this does not work I suggest removing that hard drive and slaving it into another computer to get your data off and then reload Windows onto it. It is missing a .dll
Nov 28, 2008 | Acer Aspire 1642WLMi Notebook
I installed a game software on computer 2 days ago with no problem I tried to install another game software on yesterday it started to install it scanned 200,000 viruses with no problem after it was...
i think you need to update your antivirus cos viruses might have infected the system files. Update your anitvirus or download latest antivirus and scan you system, then try to install the game. If problem persists, do a clean operating system installation.
Jun 17, 2008 | Compaq Computers & Internet
Computers & Internet Logo
200 people viewed this question
David Payne
David Payne
