Question about Motorola Mobility Bluetooth Hands-Free Speaker T305 Wireless Headset
Connection Probs with iPhone
I have tried to connect my iPhone with the Motorola T305 using the pin codes 0000 & 00000 but still not working, any ideas?
  • 1 more comment
  • mzen12 Jul 02, 2008
    The problem is solved, the code is 0000 to connect with the iPhone.
  • pjhale Aug 11, 2008
    I have the same problem and the passcode 0000 does not work for me. Any suggestions?
  • Anonymous Dec 05, 2008
    I have teh same problem. I tried code 0000 numerous times and it won't work. I also tried 00000 and still not working....HELP!
You can now send files from your iphone to other device using the ibluetooth....but its not free...you have to pay 3 or 4$ so....enjoy
Posted on Jul 08, 2009
I am trying to connect my T305 portable bluetooth car speaker phone to work with my iPhone 3G, but I keep getting Motorola T305 not paired What should I do?
Hold the power button in on the speaker system until the indicator light turns purple. Have your Iphone scan for bluetooth devices and select the T305. The first time it connects it will ask for a security key which should be 0000. If that doesn't work try 1234 as well.
At that point it should pair successfully and you should be good to go.
Please leave feedback if you found this helpful. Thanks.
Mar 25, 2011 | Motorola Mobility Bluetooth Hands-Free...
IPHONE NEED PASSWORK MOTOROLA T305 BLUETOOTH?
most blue tooth manufactures use a 4 digit pass code or pin\pairing code they are as follows 0000,1234,1111,or 9999 i hope this helps
Feb 22, 2011 | Motorola Mobility Bluetooth Hands-Free...
What does the pairing code look like on the T305 and where is it located
Most blue tooth device manufactures use a 4 digit pin or pairing code they are as follows 0000,1234,1111,or 9999 i hope this helps
Feb 20, 2011 | Motorola Mobility Bluetooth Hands-Free...
PASS CODE FOR MOTOROLA H375
Found it online said to use pass code PIN same thing 0000 used it with iphone and worked
Apr 23, 2009 | AT&T LG CU720 Cell Phone - Silver
Bluetooth/phone connection problems
If you turn on the headset and then press and hold the button until it starts flashing rapidly(or if it usually does this stays on) whilst doing this set your phone to PAIR BLUETOOTH DEVICES in the settings menu.This should pair your devices
Apr 07, 2009 | Motorola Mobility Bluetooth Hands-Free...
T305
do not just switch on the t305 .hold the on button down for at least 10 secs. much longer than the usual switch on .it will go through the normal on sequence to the pairing signal mode.do a search for device .when found pin 0000 as you have already done.
Apr 25, 2008 | Motorola Mobility Bluetooth Hands-Free...
Motorola T305 Hands free unit
the pin should be 0000. or 00000. if this fixes ur issue please give me a FIX YA rate, thank U :)
Feb 10, 2008 | Motorola Mobility Bluetooth Hands-Free...
Motorola Mobility Bluetooth Hands-Free Speaker T305 Wireless Headset Logo
433 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
