Question about Kyocera Copystar CS-1620 Black and White Copier
How to reset the unit...
Elp here... :)
Kyocera KM 1500 how to reset the unit
ERROR C-6 400
  • 38 Answers
Press and hold the following buttons in the sequence below.
(1) Stop/clear, (2) start, (3) exposure lighter, (4) exposure darker, release the 4 buttons and press the stop/clear button again. the display should now indicate 000.
below the display are 3 buttons... press the left button once, the middle button 6 times, and the button on the right 3 times. the display should now indicate 163.... press the start button 3 times.
your machine will now restart, and if the code was as a result of a power problem, should now work fine. if not the problem could be related to the fixing unit, power supply, or one of the boards.
Also do not tamper with any settings while in the service mode, this WILL have undesired effects. TAKE NOTE, this will only work if your model is the KM-1500
Posted on Jul 02, 2008
You might have to change the engine pcb board. Otherwise, then go to simulation mode, by pressing 1087 twice. Then press in 163, and press start three times. Good Luck.
Posted on Feb 25, 2014
I had error code c-6 400 and fixya solved it but immediately i finished the procedure, it brought error code c-6 000
Hi, the fuser unit will have to be replaced if several resets have been performed, or your electricity is not constant.
May 11, 2017 | Kyocera Mita Toner For Kyoceramita...
Kyocera error code c 6 400
check your fuser unit thermistor or thermostat or lamp as the following digita 1087 1087 and put 163
Jun 03, 2014 | Kyocera Mita Toner For Kyoceramita...
How to reset kyocera cs-1500
Hi Nickolas,
You may want to visit this site that has a manual of your machine in order for you to check the reset process. Hope it helps.
Kyocera KM 1500 KM CS 1500 Operation Guide Rev 2 0
Apr 25, 2014 | Xerox Phaser 4500 Printer
How do reset c-6 error code kyocera km 1500
my dear you press 10871087 after you press 163 and start baten
Jun 10, 2012 | Kyocera KM-1505 Copier
Kyocera Mita KM-1500 shows flashing c-6 and 020 Pls help
check the fixing unit thermoswitch,thermistor & heaterlamp one of them is the cause of error
Nov 22, 2010 | Kyocera Mita Office Equipment & Supplies
Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
May 26, 2009 | Kyocera KM-1505 Copier
KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Mar 02, 2009 | Kyocera KM-1505 Copier
Error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Mar 02, 2008 | Kyocera KM-1505 Copier
Reset what? The imaging unit or the toner cartridge? Replace with a new one or get a recharged one.
Feb 07, 2008 | Kyocera KM-1505 Copier
initialize all data:initialize all the backuy ram on the main board to return to the orignal setting.1-press the start key2-select(on)using zoom+/-keys3-press the start key alldata in backup ram is initialized and oriinal setting for europe country specification are set.
Jan 22, 2008 | Kyocera KM-1505 Copier
Kyocera Copystar CS-1620 Black and White Copier Logo
1,080 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
