Question about IBM Infoprint 1352 Laser Printer
93x Printhead error
Hey BradB I work at a high school and I've got this perfectly good infroprint printer and whenever I try and plug it in and print anything it gives me a "93x Printhead Error" any ideas on how to fix it?
Replace printhead (laser)
Posted on Jul 24, 2008
There are no signs of error but the paper comes out blank
Hi Zanda
if you haven't used your printer for that long, your printhead is more than likely dried up and clogged. Try running the "Head cleaning" utility 2-3 then print a "Nozzle check" (find both of these functions on "Maintenance" page under "Printer properties".
If the nozzle check shows any print, you're on the right track. Run few more head cleans or try printing several pages (with LOT of colour) on high (best photo) quality. Combination of printing & nozzle checks works best. Be prepared to waste lot of ink doing this!
If you get no print at all, it's probably time to get a new printer. There are other things you can try eg. buy set of cleaning cartridges, try to clean the printhead by placing some folded tissue soaked with Windex under the printhead or forcing some Windex through the printhead pickup (using a syringe & rubber tubing fitted over the pickup needle - where the cartridge usually sits) etc.
Another way yet is to remove the printhead from printer and soak it in cleaning solution (if if you're handy and prepared to pull your printer apart).
good luck!
Lumir
www.inkbank.com.au
REFILLABLE CARTRIDGES
Mar 02, 2014 | Epson Stylus RX425 Multifunction...
930 err0r in lexmark e350
What's the exact error code? Most of error codes that starts with 93x.xx are Printhead service errors.
May 27, 2012 | Lexmark E350d Laser Printer
Printhead error #768
The print head problem occurs if the drain tubes being clogged and is preventing the pump from sucking the ink out of the print-head. It could also happens if the ink lines allowing air into it.
There are few troubleshooting steps in trying to fix this issue. Click here for a detailed checkup.
Oct 19, 2011 | Paxar Monarch 9850 Thermal Printer
My ink tanks are full and I've run through a battery of maintenance cleanings. When printing under high quality, the words are illegible. When converting all of the text to bold print, the document is...
Sound like the printhead or the purge unit has a problem. As you can change the printhead yourself, that would be the first thing to try. If does not cure then the purge will need changing and thats an engineers job (horrible).
Good luck.
Sep 14, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My HP 2035n printer makes a horrible, long beep noise whenever someone prints. Other than the noise the printer works perfectly, no errors come up, and nothing lights up or flashes indicating something is...
I've searched and can't find anyone else with this problem either, I know it isn't an instant solution but your best bet would be contacting their customer support.
http://www.hp.com/cgi-bin/hpsupport/index.pl
May 05, 2011 | Office Equipment & Supplies
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
Printer "out of memory"
So which printer are you wanting help with?
Nov 23, 2008 | Office Equipment & Supplies
Lexmark C510 - 930 Printhead Error
93x Printhead Error
Each printhead error has its own error code number. The error codes and their respective meanings are listed below, together with some actions you can take to resolve the problem.
ALL printhead errors:
If this is the first time the error has occurred, try turning the printer off and on.
Let it sit turned off for at least 20 seconds before powering it back on.
If powering off and on the printer clears the error, please continue using the printer but watch it to see if any printhead errors return.
If your printer continues to display a Printhead Error message, make sure it is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer. This can trigger a printhead error even if the printer has worked on this surge device for months.
If the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
If the printer was recently serviced, make sure the correct parts were used. This is especially true if the parts replaced were either the printhead unit or the printer's engine/system board. It is in one of these two parts that the printer is detecting the problem. Note: If you are the person repairing such a printer, please be aware that parts from different, though similar, printer models may not be compatible with this printer. Also make sure to check the laser cable going from the printer's engine board to the printhead unit, as it reads that signal.
If the printer was not recently serviced before this error occurred and powering the printer off and on does not help, the printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
If the printer continues to post a 931 Printhead Error, it thinks there is an error in the signal going to the laser or the Hsync part of the printhead assembly.
If the printer continues to post a 932 Printhead Error, it thinks there is an Hsync error occurring in the printhead assembly.
If the printer continues to post a 933 Printhead Error, it thinks there is a failure in either the Hsync signal or with the mirror motor unit of the printhead.
If the printer continues to post a 934 Printhead Error, it thinks there is a "lock" failure with the mirror motor assembly within the printhead assembly.
If the printer continues to post a 935 Printhead Error, it thinks the mirror motor unit within the printhead unit cannot reach its operating speed.
If powering the printer off and on does not clear any of these errors and it is already connected directly to the wall, your printer may require service. It could have a defective printhead unit or there might be a problem with the engine board or one of the printhead cables. Note: If you are the person repairing such a printer, check all of the cables going from the printer's engine board to the printhead unit for any damage. Also check the continuity across these cables.
Source: Lexmark KnowledgeBase
Jul 28, 2008 | Lexmark C510 Laser Printer
Infronprint 1352 93x Printhead error
Basically this is a Lexmark printer.
Try these if no result replace printhead ( can be expensive will try to find the comparable to the lexmark.
93x Printhead Error
  1. If this is the first time the error has occurred, try turning the printer off and on.
  2. Let it sit turned off for at least 20 seconds before powering it back on.
  3. If powering off and on the printer clears the error, please continue using the printer but watch it to see if any printhead errors return.
  4. If your printer continues to display a Printhead Error message, make sure it is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer. This can trigger a printhead error even if the printer has worked on this surge device for months.
    • If the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
      • If the printer was recently serviced, make sure the correct parts were used. This is especially true if the parts replaced were either the printhead unit or the printer's engine/system board. It is in one of these two parts that the printer is detecting the problem. Note: If you are the person repairing such a printer, please be aware that parts from different, though similar, printer models may not be compatible with this printer. Also make sure to check the laser cable going from the printer's engine board to the printhead unit, as it reads that signal.
      • If the printer was not recently serviced before this error occurred and powering the printer off and on does not help, the printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
    • If the printer continues to post a 931 Printhead Error, it thinks there is an error in the signal going to the laser or the Hsync part of the printhead assembly.
    • If the printer continues to post a 932 Printhead Error, it thinks there is an Hsync error occurring in the printhead assembly.
    • If the printer continues to post a 933 Printhead Error, it thinks there is a failure in either the Hsync signal or with the mirror motor unit of the printhead.
    • If the printer continues to post a 934 Printhead Error, it thinks there is a "lock" failure with the mirror motor assembly within the printhead assembly.
    • If the printer continues to post a 935 Printhead Error, it thinks the mirror motor unit within the printhead unit cannot reach its operating speed.
  5. If powering the printer off and on does not clear any of these errors and it is already connected directly to the wall, your printer may require service. It could have a defective printhead unit or there might be a problem with the engine board or one of the printhead cables. Note: If you are the person repairing such a printer, check all of the cables going from the printer's engine board to the printhead unit for any damage. Also check the continuity across these cables.
Jul 02, 2008 | IBM Infoprint 1352 Laser Printer
Kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
IBM Infoprint 1352 Laser Printer Logo
106 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Toby
Toby
Level 1 Expert
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
