I have a harman kardon cdr20 that I need to fine how to make record the cd from 1 cd to the other
  • 682 Answers
Http://safemanuals.com/user-guide-instructions-owner-manual/HARMAN%20KARDON/CDR%2020-_E
Posted on Jul 02, 2008
Looking for an internal parts diagram for a Harman Kardon CDR2
Where do you live? Sarasota electronic has belts if its wrotten take machine and belt I am in florida
Apr 03, 2013 | Harman Kardon CDR2 2-Disc CD Recorder
I have a Harman Kardon crd20 and when trying to record i'm getting "no audio" what is the problem? And is it possible to get a manual?
"CRD20"
A simple web search, which you could do yourself, for "Harman Kardon CDR 20 manual" finds several.
http://www.retrevo.com/support/Harman-Kardon-CDR-20-CD-Players-manual/id/386dj191/t/2/
Look for "no audio" in the manual. It occurs twice.
Aug 27, 2011 | Harman Kardon CDR20 CD Player
After i have finish recording and i am finalizing the the cd code OPC appears on the screen, and being finalize the cannot play in other cd player why?
OPC means the unit had trouble Optical Processing Calibration, which means the disc surface may be damaged. Using brand name media and being careful to not touch the recording surface would help.
It's not completing the finalization so it won't play in a CD player yet.
It's mostly in the manual
OPC: Stands for Optical Processing Calibration.
When you see this message in the Information
Display for the Record DeckK, it means
that the laser transport inside the unit is making
the calibrations and adjustments needed so that
the recording process is optimized for the specific
disc in use.
When an unfinalized CD-R or CD-RW disc is
placed in the Record Deck%, the letters
OPCwill flash once the Table of Contents has
been read. This indicates that the unit is optimizing
its circuits for maximum compatibility with
the specific recordable disc in use. the number
and total running time of any tracks that have
already been recorded will appear in the
Information DisplayK, and the appropriate
indicator SPwill light to tell you if a CD-R or
CD-RW disc is in use.
To Finalize a disc, place it in the Record
Drawer%. Once the disc's Table of Contents
information has been read and the OPC process
has been completed, press the Finalize button
E@and note that the Finalize Indicator
Uwill begin to flash. Within three seconds,
press the Select button9*and note that
the Finalize IndicatorUwill stop flashing.
The Finalization process will take up to two
minutes, depending on the length of material
recorded on the disc. During the Finalization
process the Record Deck will not accept any
operating commands.
Dec 29, 2010 | Harman Kardon CDR20 CD Player
HELLO I AM HAVING STATIC WHEN I RECORD OR MAKE A CD NOW * IT STARTS ABOUT HALF WAY THRU THE CD I AM MAKING* BUT IT'S NO WAY OF KNOWING HOW IT'S GONNA TURN OUT TIL I AM COMPLETED THE ENTIRE CD* WHAT IS...
The 'static' is the unit's error detection, -correction and -concealment strategies being exceeded so it puts out the best digital-to-analog translation it can come up with.
You could prove that by playing it on another player and if you get a non-identical result (for example, it starts making the noise at exactly the same point) the data may be marginal but the player's abilities may differ.
If it IS exactly the same, the data is certainly corrupted.
I'd suspect the media. Is it name brand or CD's-r-us cheapo media?
Jun 23, 2010 | Harman Kardon CDR20 CD Player
Just want a manul
You can download the complete instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 27, 2010 | Harman Kardon CDR2 2-Disc CD Recorder
Have no instructions
Go to retrevo.com, register and download it for free.
You need to finalize the disc for players to read it.
May 03, 2010 | Harman Kardon CDR20 CD Player
Does anyoe know how to record from LP to cd?
Use your tape out, or another line out signal from your preamp.... if possible - OR Sometimes you can pull out some connectors on the back of your amp (a Metal joint kindathing ;), to break signalpath between preamp and poweramp if its an integrated amp -
Use preamp out signal to feed your cdr ( Main purpose is to equalize out, the RIAA correction on a record)
Have you tried to google your question ? Lots of fine guides out there!!!
Jan 14, 2009 | Harman Kardon CDR2 2-Disc CD Recorder
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
HARMAN KARDON CDR-26 CD RECORDER/PLAYER
You need to clean the laser lense, if that doesn't work you need a new laser pickup. Check first, but from memory you need a sanyo sfp151 17 pin laser. Costs around $25.
Mar 08, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
55 people viewed this question
 Grubhead
Grubhead
