Question about HP Photosmart C6180 All-In-One InkJet Printer
Magenta cartridges not working
In trying to print labels, I believe the printer "ate" one and then I had an error (didn't write the # down), the printer made terrible noises and then the magenta cartridges did not work after this. All the other colors, including black, work fine, but of course no combos using magenta are printing, so unable to print in red, etc.
I tried all the resetting/reinitializing methods, but no solution has worked. Please help!
  • 10 more comments
  • Kolina Jul 02, 2008
    Sorry, your answer was way too basic. Yes, I've done both of these things. I need a more in-depth/complex answer to my problem.
    As stated, all colors (including black) seem to be working just fine. I've changed out cartridges, done a reset, etc and nothing seems to work. I definitely need EXPERT help. Thanks.
    Yes, I've done a head cleaning through the software. This still does not solve the "magenta not working" problem. I'm totally baffled.
    I've done all the major steps suggested by HP, which includes the 'print head cleaning' as well.
    I truly need a more complex solution to this issue of 'magenta not working'. Thanks anyway.
    Is there a way to open up the printer and take a look inside? I need to find what happened during the 'original issue' of the printer possibly eating a clear label.
    After this happened, I was no longer able to print with the magenta colors (I was using red on my document at the time of the 'original issue').
    I have a MAC computer. I just cleaned the print heads (before you posted your possible solution) by accessing the HP software. This is the second time I've done this and IT STILL DOES NOT FIX MY PROBLEM. Thanks for trying, though.
    My issue is rather complex, I believe.
    I feel that due to a malfunction when printing labels (jam and/or 'eaten' label) it has somehow caused the magenta cartridges to quit working. I have replaced these, cleaned contacts, done a software cleaning, done a reset, etc. I am still able to print documents, but color mixing using red is simply not working. I only have black, yellow and blue that work, but nothing in the red family is working at all.
  • Kolina Jul 03, 2008
    Still needing help with how to repair magenta ink cartridges and/or printer. (All other colors, including black, are working fine). Problem happened when I was trying to print labels and the printer somehow "ate" one - as far as I can tell. Then some horrible noises came from printer and then magenta quick working.
    1. Where is the mylar ribbon cable located?
    2. How do I access it? I would need specific instructions in how to disassemble the printer.
  • Kolina Jul 10, 2008
    I took the printer in to have it repaired, but they could not find the 'eaten' label and as far as they could see, the Mylar ribbon cable was intact. Is there any other solution to try to get the magenta cartridges to work once again . . . short of sending it to HP? I'd appreciate any expert input/solution!
    Actually, I couldn't find the printer cartridge if it hit me in the face . . . the reason being is that I'm unable to access anything easily with this printer without probably tearing it all apart, which truthfully scares me to death. This printer is a real pain!
    Thanks, anyway.
    oops! I meant print carriage, not print cartridge. Sorry.
  • HP Master
  • 1,879 Answers
Greetings,
Service for that unit if you do not have the experience opening printers.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jul 10, 2008
    President:
  • 1,257 Answers
If you get any error message please reply it so that we can troubleshoot it and provide you the solution
    Master:
  • 788 Answers
In my opinion your printer is broken if you've done all the cleaning/reset steps. Have you checked in the print cartridge carriage for you missing label, it may be covering up the magenta print head, but if this were the case then you would probably have an awful mess of magenta ink everywhere.
It could be that the trailing cable that goes from the carriage to the engine board has come loose causing the magenta signal to be lost. Hopefully the cable is not ripped but just came out of its connector. You might be able to check it without taking the printer apart but it might be hard to see. Taking the printer apart is possible with some trial and error, there really isn't instruction readily available to do so. I suggest taking a lot of digital pictures while you take it apart so you can refer to them when putting it back togerther.
You say you checked the contacts? Did you check the ones in the print carriage. If there is something blocking the contacts in the magenta compartment then the cartridge might not be getting a signal. I suggest cleaning it with a cotton swab and some Isopropyl Alcohol then cleaning it with the eraser from a pencil.
If the cable checks out and the contact are clean then I'm afraid there has been an electronics fault on the engine board. The C6280 is the current equivalent printer and retails for about $180 so having your C6180 repaired probably isn't a good value.
Just for the future, never reuse a sheets of sticker labels if you've already removed some of the labels, always use a fresh sheet, this helps avoid labels getting peeled off in the printer.
Posted on Jul 03, 2008
    Sniper:
  • 114 Answers
As you stated, there was a terrible noise and then the magenta failed to print. I would check the mylar ribbon cable for any damage. especially since it could have torn or been damaged. the ribbon cable is responsible for the signal for magenta to print. it more than likely is either the cable or the seating where the cable terminates on either side.
    Genius:
  • 1,665 Answers
If problem continuous take it to an authorized service station to estimate repair cost.
Unfortunately as i know buying a new printer may be not more expensive than repairing or replacing printheads
Posted on Jul 02, 2008
  • 2,071 Answers
Try to clean your printheads or check the level of your inks, maybe you are low inks and try replacing them with genuine HP ink cartridges not the generic one .
If the print defect is minor,it might be caused by reserve mode operation .When the printers runs out of some colors ,it can continue printing using remaining inks ,but prints quality may be affected .If cyan, magenta or yellow is out the printer can print only in grayscale.
Replace any empty print cartridges .To check ink levels
follow the steps below;
1. press the SETUP button.
2. press the down arrow button until TOOLS is highlighted.
3. press OK.
4. the display ink guage selection should be highlighted .PRESS OK and the ink gauge will display.
or try to calibrate the colors;
1.open the printer TOOLBOX.
*open HP SOLUTION CENTER( click START,then ALL PROGRAMS,then HP SOLUTION CENTER)
*if you have more than one printer installed ,make sure to select the correct printer tab in HP SOLUTION CENTER.
*click settings
*click PRINT SETTINGS..
*click PRINTER TOOLBOX
2.on the DEVICE SERVICES tab click CLEAN THE PRINT CARTRIDGES,and then follow the onscreen instruction three levels of cleaning are available
    Guru:
  • 1,342 Answers
Try cleaning the copper contacts on the cartridge and in the printer with alcohol.
    Brigadier General:
  • HP Master
  • 3,614 Answers
Have you try to switch and replace another color catridge...?
  • micromaster
    micromaster Jul 02, 2008
    if there a utility maintenance on the software try to do a head cleaning..
    thank you
  • micromaster
    basic, cause I was first initiating on what steps method you have done.. Initially things can be done on the step by step procedure, before we go on to the advance...
    thank you for using fixya
10.1002 supply error
This error indicate the affected cartridge...
10.1002 = Magenta e-label is missing..
you need to reinstall the printer..
Are you sure that the print cartridges are genuine!!
->Open the front access door completely.
->Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
->Grasp the center of one of the print cartridges, and then pull it straight up to remove it.
->Hold the print cartridge so that the imaging drum faces the bottom of the print cartridge drawer, and then insert the print cartridge into the correct slot.
->When you are sure that you have genuine print cartridges installed, close the print cartridge drawer completely.
->Close the front access door completely.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 26, 2012 | Office Equipment & Supplies
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
My son-in-law is a computer and cash register repairman. He checked my printer out and thinks that I have a bad charging device problem. Black print works great, but colors just will not work. Blue toner...
The error code 10.0002 is a problem with the magenta cartridge. To be precise it is a e-label error.
The e-label is a small circuit board on each of the cartridges.
Pull the magenta cartridge and clean it.
Now as to the ETB (that's the big mylar sheet with the cyan toner all over it). Get rid of the cyan cartridge, it's obviously dumping toner. Remove all the cartridges and the ETB, and vacuum out the printer...with power off.
Power the printer on and when it comes ready
1. press the select button(check mark)
2. press the - and the 'cancel job' button together (at the same time). release both
3. press the select button. You now should be in the 'secondary menu'.
4. press either left or right arrow buttons to navigate.
5. navigate to CLEAN ETB
6. press select(check mark) and let the machine do its' thing.
Good Luck
Do get rid of the cyan and probably the magenta.
Feb 15, 2011 | HP Color LaserJet 2600n Printer
My Epson R230 printer does print Light magenta and yellow ink
1. open a document. 2. control-P - shortcut for print. then click properties, click maintenance, then click head cleaning. after this print check pattern. continue doing this until your light magenta and yellow ink gets clearer. if it didn't work replace your light magenta and yellow cartridge.
Nov 18, 2010 | Epson Stylus Photo R300 InkJet Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer error code 5952 - ?
From the service manual:
An error occurred with the magenta printcartridge drive motor during startup or rotation.
To fix:
1. Check that connectors J5003 on the magenta print-cartridge drive motor and J207 on the DC controller are seated correctly. If they are then:
2. Replace the magenta print-cartridge drive motor. If that doesn't work then:
3. Replace the DC controller.
Jul 08, 2009 | HP LaserJet 3600n Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Just replaced color inks but giving error 10.0002 Supply error
Seems to be a problem with the magenta cartridge try removing it and reinstalling it also make sure you removed all the tapes that it had.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00314875#A8
This is what HP say :
Description E-label cannot be read or print cartridge is not properly installed. Action
  1. Open the front cover of printer and remove the toner cartridge exhibiting error.
  2. Inspect the print cartridge to ensure the e-label reader is attached to print cartridge and is not damaged.
  3. Inspect the inside of printer to verify the e-label does not have any product packing tape still attached.
  4. Inspect the e-label reader to ensure the gold contact points are not damaged or bent. Also inspect the black plastic on e-label reader to ensure it is not bent or broken.
  5. Reinstall the print cartridge.
  6. Power cycle the device.
  7. If reinstalling the print cartridge does not resolve the issue, replace the print cartridge.
  8. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
May 09, 2009 | HP Color LaserJet 2600n Printer
Dell 920 printer won't print magenta.
There are chances the magenta ink got over or its dried :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer. try this if this did then heat the cart cartridges walls with hair dryer for 2 min then insert it back and check if it works:
Feb 24, 2009 | Dell A920 InkJet Printer
What does 10.0002 supply error mean?
10.0002 Magenta cartridge e-label error Error message 10.0002 supply error alternates with Reinstall c00381084.jpg with a ? under the Magenta print cartridge gas gauge Description E-label cannot be read or print cartridge is not properly installed. Action
Dec 03, 2008 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
372 people viewed this question
Ben Johnson
