Question about Mitsubishi VS-70707 70" Rear Projection Television
After my 70" tv is on for a period of time, it turns off and won't come back on for a while.
It appears that it has to cool off for a few minutes and then we can turn it back on. Sometimes it will work for hours without any problems and then sometimes it turns itself off often.
  • 927 Answers
Good Day, Connie ss;
The next time the TV turns off try this:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. I hope this was helpful, good luck, big IRISH.
Posted on Jul 20, 2008
Air conditioner damper
Could be a blend door problem under the dash.
Jun 17, 2013 | 1998 Jeep Grand Cherokee
Good afternoon, I have a Sony TV KDF-LSD E50A11E overhead projector, a few months now I've changed the bulb and turn on the TV and some time it turns itself off and the red light blinks 2 times,...
it could be a cooling fan or power supply problem or a switch on the saftey inter;lock on the lamp door
it will require some trouble shooting if your having problems finding some one in your area contact sony for a referal to a servicer in your area
Jun 05, 2011 | Sony KDF-E50A11E TV
We installed a new ceiling light fixture in our hallway. I used the 13W CFL bulb. Just recently, I turn on the light and a hour or so later it turns off. It takes a few minutes before I can make it turn...
DON"T USE TILL YOU FIX- the connections inside fixture are getting hot and expanding- OPEN SHORT_FIRE HAZARD- that is why going out after an hour and then works after a few minutes of cooling- take down and check you connections
May 18, 2011 | Hardware & Accessories
2000 buick la sabre was working very well. it sat
try dumping some gas line antifreeze into the tank
Jul 28, 2010 | 2000 Buick LeSabre
GE 46GW948 shuts off when cold then works fine
This is a classis symptom of poor solder connections that when heated connect well. If you can solder, you should be able to fix this yourself. Resolder any connections that appear to be grainy or have rings. Note: The most likely location of these poor connections are at the convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. There are high voltages floating around inside these sets even when unplugged, so be careful.
Keep me posted.
Dan
Oct 27, 2008 | GE 46GW 948 46" Rear Projection Television
DLP tv trouble shooting
Hi.
Yes it could be a cooling problem, If your tv has any filters remove & clean them ensure fan can turn freely & that nothing can or is snagging it.
http://dysonmanuals.inc.io/
Chris.
Nov 09, 2007 | Televison & Video
Mitsubishi VS-70707 70" Rear Projection Television Logo
125 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
